Will replacing front leaf springs add any height?
I can't quite seem to get a good answer about this, ive got a 69 4x4, stock height and the front end has been looking a little low for my liking lately. ive got the 2 leaf springs on each side, and i was wondering if replacing them would be a good way to add just a little more height, because i don't want to mess around with lifts. could i upgrade to the 3 leafs in front, for the effect I'm looking for?
thanks guys, if anyone can refer me to where i could find these replacements that would be most appreciated. thanks!! |
Re: Will replacing front leaf springs add any height?
the blue truck is mine, currently. 3/4 ton
the green trucks height is close to what I'm looking for, perhaps a small bit lower |
if the front leafs are original. im sure they are sagging. so even replacing to the same should bring it up a little.
phillip |
If the axle is under the leafs you can add a block. I don't have a 4x4 so I have no idea if the leafs are over or under the axle
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
All about them K’s
![]() Join Date: Jun 2014
Not on the front end... That's a recipe for disaster while driving down the road.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#6 | |
Moderator
![]() Join Date: May 2007
I would buy a complete quality 2.5" lift kit if it were mine. It is mild and will achieve the look you are after without any dramatic effects on suspension geometry.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
All about them K’s
I was actually contemplating the same advice but the op said he wanted to stay away from lift kits. I agree 2.5" will get you what you want.
#8 | |
Any suggestions? Also to the OP don't be deceived the SWB can play tricks on your eyes appearing to have a different stance too. NO doubt the years and miles on your original springs could use some love I have a long bed as well and the stance always looks different to me compared to a swb Good luck and keep us posted as to what you do and how it turns out |
20' Daredevil (Ret)
![]() Join Date: May 2003
You say the blue truck is your 3/4 ton. I count six lugs...???
At any rate, one more vote for sagging front springs, replace with new 2.5" springs. In fact that's what I did several years ago and have never regretted it. I used Skyjacker Softrides. No changes needed except for longer front shocks. Stock rear shocks are the correct length, extended and compressed.
Rusty Nuts
I replaced mine and it was a two leaf and purchased the two leaf that i thought would give me just a little more height cause they would be new, but nope it looked the same after installed. Had to do bushings anyway. Go with an extra leaf to get a little more height.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
![]() Join Date: Dec 1999
Are there not spring shops anymore? You used to be able to get your springs rearched.
You can add a zero rate spring from ORD, adds 1" without changing ride. Or an add-a-leaf, use the long one, and you'll have an HD suspension setup like my 68 K-10 did from factory.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
