09-29-2015, 10:34 AM | #1 |
A little body work hack for the detail line on wheel arches
I just replaced the wheel arches on the bed of my '70. Where I joined the metal toward the bottom I needed a little bit of filler to cover where my weld was. Found a solution for spreading filler and creating a perfect detail line.
That's right, it matches the factory contour perfectly. Just wanted to share, thought it might make someones life a little easier |
09-29-2015, 10:40 AM | #2 |
Re: A little body work hack for the detail line on wheel arches
Nicely done.
Looks like it could be modified pretty easily to accomodate other shapes, too. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-29-2015, 10:51 AM | #3 |
The Older Generation
Thanks for that. I fought mine for 2 days.... LockDoc
09-29-2015, 12:31 PM | #4 |
wrap that bad boy in sandpaper and you have a perfect block for that area. Jim
09-29-2015, 01:53 PM | #5 |
^ Yup! Been putting a little bit of 180 grit PSA paper on it and it works like a charm!
