Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-30-2015, 01:44 PM   #1
19SIKtySix
19SIKtySix's Avatar
Question Welder Question
Hopefully somebody can help me out...I have a 110v Snapon welder that I'm having some issues with. I hooked it up to give it a try and was getting a lot of pop on my welds. I double checked the ground and my gas pressure (it was about 17psi) but no luck.
Now this welder has been put thru it's fair share of work and was stored outside but under cover, so I thought it was time to replace it. However, before I go and purchase another welder, I want to make sure it's not a power problem.
My question is, could I be plugging into an outlet and the welder not be getting enough power? Anybody know of a way I can check the load on a breaker? My garage has about 12 plugs in it (some are GFIs, which is what I had it plugged in to), I was hoping to find a way to verify the welder is getting enough juice.
Chuck
Instagram: c_lo_garage
Check out my 1966 C10 project "El Viejito" here:
http://67-72chevytrucks.com/vboard/s...d.php?t=674614
19SIKtySix is offline   Reply With Quote
Old 09-30-2015, 01:50 PM   #2
leuggy
Re: Welder Question
did the GFI plug ever trip when using the welder? I wouldn't use a GFI plug for a welder use a normal plug, just 120 volt welder ?
Blaine
leuggy is offline   Reply With Quote
Old 09-30-2015, 01:53 PM   #3
67swb72klb
67swb72klb's Avatar
Re: Welder Question
Blaine
X2 no small gauge extension cords also
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-30-2015, 02:08 PM   #4
19SIKtySix
19SIKtySix's Avatar
Re: Welder Question
Blaine
No, the GFI didn't trip, I was thinking it'd be better to plug into a GFI in case there was an issue. Like I said, I have quite a few outlets around the garage, however I haven't tried plugging into each one.
I was planning to take some time this weekend and work on this more. I'll try plugging into a normal plug. Also I wasn't using an EC, just the standard cord for the welder, I believe it's like a 25' cord. Thanks for your suggestion
Chuck
Old 09-30-2015, 02:09 PM   #5
19SIKtySix
19SIKtySix's Avatar
Re: Welder Question
No, I didn't have an EC plugged in, just the supplied cord on the welder...I'm going to try using a normal outlet tonight, thanks.
Chuck
Old 09-30-2015, 03:35 PM   #6
msgross
msgross's Avatar
Re: Welder Question
Are you sure it's not the metal you were welding? voltage on welder not set properly, speed of wire? Lots of variables.
BTW, All outlets in a garage are required to be on GFCI, at least newer garages are so it wouldn't matter which outlet.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-30-2015, 03:46 PM   #7
Bigdav160
Bigdav160's Avatar
Re: Welder Question
I once owned a SnapOn mig welder. I think it was a YA205 made by Century.
Some days it would weld great, other days terrible.
What was wrong with it was the gas solenoid inside the machine. It would intermittently cut back the gas flow.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-30-2015, 03:56 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Welder Question
This ^^^
Any grease, oil paint or rust on the metal can make it pop.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-30-2015, 04:32 PM   #9
19SIKtySix
19SIKtySix's Avatar
Re: Welder Question
It very well could be the metal, I was testing the welder on an old brake drum...I ground down my weld area and the ground area, but I could have easily left some rust/possible oil on the drum
The model I have is a YA219, like I said it's been in my family for awhile. My nephew had been using it, but it was outside and I noticed when I got it back that there were remains of wire on the ground, splatter in the nozzle, some wire had rust, etc.
I don't want to blame him, so I'm trying to verify if the welder is still effective or if there are other issues, that a new welder won't solve before buying a new one.
Originally Posted by GASoline71 View Post
This ^^^
Gary
I'm going to try some other metal tonight, I just recently got a small sheet of 18ga, I'll use a piece of that to test. I was trying to find some thicker metal for a good bead. I'm going to look over the brake drum again and make sure both areas are cleaned really well.
Thanks guys for all the feedback, this helps.
Chuck
Old 09-30-2015, 06:10 PM   #10
truckster
truckster's Avatar
Re: Welder Question
I would turn the heat and gas both up beyond what you need for the thickness you're welding. Clean the weld area well (I use brake parts cleaner to degrease) before you start, and make sure the area where you attach the ground is clean as well. You'll burn through 18 gauge, but it should eliminate any pop and you'll know for sure if it's a power or gas delivery problem.
truckster is offline   Reply With Quote
Old 09-30-2015, 06:23 PM   #11
19SIKtySix
19SIKtySix's Avatar
Re: Welder Question
That's a good idea, thanks for the info...I'll try to use these tips tonight and see if there's any difference.
Chuck
Old 09-30-2015, 07:27 PM   #12
Bigdav160
Bigdav160's Avatar
Re: Welder Question
I've been told to NEVER use brake parts cleaner before welding. Some of those sprays do not evaporate well like the old days.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 09-30-2015, 08:45 PM   #13
truckster
truckster's Avatar
Re: Welder Question
When I use brake parts cleaner before welding I put it on a paper towel and use the paper towel to degrease the area I'm welding. That way it doesn't pool up. I also make sure the paper towels are disposed of well away from my welding area.
I think any solvent is dangerous if not used properly.
Old 09-30-2015, 10:54 PM   #14
67swb72klb
67swb72klb's Avatar
Re: Welder Question
Brake drums are cast iron and don't like to be welded...I would stick with some clean sheet metal
Old 10-01-2015, 11:15 AM   #15
19SIKtySix
19SIKtySix's Avatar
Re: Welder Question
So I got home last night and tinkered with the welder, I wanted to try on the sheet metal piece that I have. I tried another outlet (whether that matters or not) and started thinking is there anything else I can do. Well from the welder being outside before, I decided to clean up the ground clamp. I wire wheeled the clamp itself, the contact on the ground wire, and even cleaned up the nut which had rust on it.
I played with the settings on the welder (like what was suggested earlier) and layed down some tacks on the sheet metal:
You can see as I tweaked the settings from top to bottom, the results got better...needless to say I was stoked to find out my welder isn't complete junk. I don't plan on doing any heavy welding, but if I keep tweaking the welder, it should take care of the little tasks I need it for. When I was laying down the tacks, I could hear that familiar buzz sound.
Chuck
Old 10-01-2015, 11:18 AM   #16
19SIKtySix
19SIKtySix's Avatar
Re: Welder Question
That could be part of the problem, I know the brake drum is rusted up pretty good, plus my negative clamp had some corrosion. Perhaps the areas I cleaned weren't clean enough. I just know that no matter what I did, I got bird crap welds. I never could get that good buzzing sound, but I finally did when tacking on the new sheet metal.
Thanks for your input, I appreciate it!
Chuck
Old 10-01-2015, 11:52 AM   #17
GASoline71
GASoline71's Avatar
Re: Welder Question
Using brake cleaner to remove grease and then welding can kill you...
The fumes from Phosgene gases are deadly.
http://www2.worksafebc.com/i/posters/2013/ws_13_09.html
Gary
Old 10-27-2015, 09:14 PM   #18
Steven R
Re: Welder Question
just a question for you, you said the welder was outside, was the wire still in the welder at that time. I have had issues with a contaminated roll of wire that had gotten wet and then corroded.
Have you tried a new roll of wire? and when is the last time you change the contact tip, or at least insured matched contact tip and wire size.
my two cents hope it helps
Steven R is offline   Reply With Quote
Old 10-28-2015, 04:41 PM   #19
Sluggo
Re: Welder Question
as stated above by Steven R, it could be rust on the wire which in turn would cause your liner to partially clog and that will make the wire drag and cause that same problem, if its been outside pull the wire out of the liner and shoot some cleaner, not brake cleaner, maybe something like maf sensor cleaner or whatever into the liner until it comes out clean then relube it with mig lube you can get at the welding supply store, that should help solve your popping problem as well and try not to practice on brake drums as mentioned above, ive been in the welding industry for 40 years or so, just a little background on me, good luck
Sluggo is offline   Reply With Quote
Old 10-29-2015, 04:54 PM   #20
cg285
Re: Welder Question
one of my employees came from cuba. one day he decided to weld something with my miller 200. he says something like "wow dees muchine weds mu bueno"
laughing i says if you think it welds good now try it with the gas on.
cg285 is offline   Reply With Quote
Old 10-30-2015, 01:27 AM   #21
Clavo106
Re: Welder Question
if this helps any weld aid.on old wire I have it on my mig.. ... https://weldingsupply.com/cgi-bin/ei...UNDEF:X:007062
Clavo106 is offline   Reply With Quote
