Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-07-2015, 04:36 PM   #1
CarterD2015
CarterD2015's Avatar
Flooring question
I am in the process of building my first shop and I have no idea what to do with the cement floors. I intend to use the bulk of the space for storage of completed vehicles and use one 20 ft bay with a two post lift to work in. I would like for it to look nice for years to come.
With that said should I use one of the two part epoxy systems, or garage floor epoxy paint or just seal the floor? I am also open to any other ideas.
Tell me what you guys think. Thanks for the input.
Dennis
37 ford coupe
68 short narrow
72 short wide
CarterD2015 is offline   Reply With Quote
Old 11-07-2015, 11:26 PM   #2
Advanced Design
Advanced Design's Avatar
Re: Flooring question
I don't have experience on the epoxy systems though I am sure someone here will jump in. Wow, your building looks huge! What are the dimensions?
Advanced Design is offline   Reply With Quote
Old 11-07-2015, 11:33 PM   #3
CarterD2015
The building is 60 x 60. It will have a 20 x 30 "mother-in-law" quarters and a 20 x 20 room for me. I can't wait to get it finished.
Dennis
37 ford coupe
68 short narrow
72 short wide
Old 11-08-2015, 09:40 AM   #4
Advanced Design
Sounds like a great building! Wife and I have talked about doing something similar. They call them a shouse around here. Combination shop and house.
Car dealerships typically have an epoxy applied which lasts for years under heavy use. Perhaps you could consider that?
Old 11-08-2015, 03:17 PM   #5
_Ogre
_Ogre's Avatar
seal it and be done, is what i've always done in the past
do it before you get oil all over it
shop air compressor timer
Old 11-08-2015, 11:28 PM   #6
BlueBullet
BlueBullet's Avatar
When I talked to my concrete guy he said leave it or use high grade epoxy. The do it yourself stuff you get at Menard's or stores like that do not hold up. I left mine because of budget.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 11-08-2015, 11:42 PM   #7
CarterD2015
I've read many horror stories about the diy epoxy coatings. I would hate to install it and have it start to bubble and peel. I would be putting it on 2600 sq ft and it would a nightmare to fix if it wasn't right.
Right now I am leaning toward painting the floors.
Dennis
37 ford coupe
68 short narrow
72 short wide
Old 11-09-2015, 03:12 PM   #8
bs46488
Dennis,
I bought a house a couple of years ago and before we moved anything in, I did the DIY epoxy from the box store. When we first moved in it looked great.
Unfortunately a couple of years later the floor has started to fail in spots. And when I scrub areas to clean up spills the finish is "off" (kind of like I smeared it)
The other unexpected issue....I picked the tan floor with the white/black/brown flakes. It makes the perfect camouflage for dropped nuts and bolts. I dropped a grade 8 washer the other day and spent 10 mins trying to find it on the floor.
bs46488 is offline   Reply With Quote
Old 11-18-2015, 08:54 PM   #9
Rod Run
Rod Run's Avatar
I have used the DIY epoxy system and had excellent results. Other I know have had good and bad. The good ones did it right and the failures took shortcuts, because they "didn't think all the steps were important".
You have to follow the directions EXACTLY as stated or you will have failures.
Just like bodywork on a car.... Prep is the most important part. Once cleaned, don't assume the floor is ready to coat. Test it out first as they say to do.
Also, do it only in-between the temperature range that they say is necessary. Any colder and you will end up with lifting. I also waited almost a week more than recommended, before I put it to any abuse.
Just be careful of your color choice or you will be losing stuff on the floor. LOL
There are also major differences between water-based and solvent-based systems
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 11-18-2015, 09:14 PM   #10
CarterD2015
I think that I am going to paint the floor.
http://www.eastwood.com/drylok-e1-ep...ural-sand.html
That way it can be touched up if needed. If it fails it will be easier to remove. I realize that may not be as durable. It will be easier to change colors if I want to in the future. Not to mention that it is 1/3 the price of the two part epoxy systems.
Dennis
37 ford coupe
68 short narrow
72 short wide
Old 11-18-2015, 10:09 PM   #11
Advanced Design
Dennis, glad you found your flooring material. Your building is going to be a nice one. Maybe you can share progress pictures and ideas here? I know I would enjoy tagging along...and it sure beats watching TV!
Old 11-19-2015, 09:26 AM   #12
Hardworkinguy
I used the water-based epoxy system from U-Coat-It,and was happy with the results. It has never peeled up in big chunks like some of the paints or other epoxies I have seen. My driveway is gravel,and I do auto repair out of my garage full time,so the main areas between the bays have pretty much worn away,but the rest of the floor is still holding up very well.
This photo is from about 9 years ago. The place needs a total clean and reapply of the floor epoxy now.
Hardworkinguy is offline   Reply With Quote
Old 11-19-2015, 08:47 PM   #13
drfloyd
It sounds like the floor is poured so it's too late to dye the concrete like I did mine but that's the sure fire way to have a floor that keeps it's color forever and even if it chips you can hardly tell it since it's colored all the way through. It's the perfect option for a shop or garage floor. My second suggestion is Tenemec. I work in the power industry and Tenemec is the epoxy that is used on all turbine floors. It's virtually indestructible is it's installed properly. I know it's available in 2 part but I think they have a single stage as well.
drfloyd is offline   Reply With Quote
Old 11-19-2015, 09:50 PM   #14
65Gregg
65Gregg's Avatar
Garage journal.com has a forum dedicated to flooring, lots of info and reviews.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 11-20-2015, 08:10 PM   #15
Rod Run
Rod Run's Avatar
I'm a member over there and that's where I did all my research and learned the pros and cons of the different epoxies.
Old 11-23-2015, 10:17 AM   #16
Foot Stomper
Foot Stomper's Avatar
My day job is technical sales for Rustoleum Inustrial Brands which includes floor coatings.
If you don't have a properly prepared and clean surface, any and all kinds of paint or epoxy will fail in the short term. Failure will be lack of adhesion regardless of brand.
If you are going to pour a new floor or coat an existing floor, there are different products and procedures for each.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 12-02-2015, 05:09 PM   #17
CarterD2015
New pic of the shop today. Got a little tin put on...finally. I hate to complain about the rain here in Texas because we need it so bad but I want my shop finished.
Dennis
37 ford coupe
68 short narrow
72 short wide
Old 12-04-2015, 10:28 AM   #18
drfloyd
Nice shop. I know you are antsy waiting on it to get done. We have the same issue with rain here in SC. I have about 100 yards of concrete I want to pour and can't get a break in the weather to get trucks on my property.
Old 12-08-2015, 05:08 PM   #19
68C15
blood type; Retumbo
68C15's Avatar
Smear oil and grease on the fresh concrete. Toss in some dirt and work it real good into the surface. If done right you will have a totally impenetrable surface for all eternity
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-19-2015, 01:25 AM   #20
OhioChevy
Smile Re: Flooring question
CarterD2015, you are going to have a nice building. Please keep the pics coming as you build it. I will be following your progress.
Ray
OhioChevy is offline   Reply With Quote
Old 12-19-2015, 07:19 AM   #21
beautimus
beautimus's Avatar
first question is --did you put down a moisture barrier before you poured the slab?
concrete can "wick" moisture from the ground up thought the slab. if you put a coating over it, it can fail due to the moisture wicking up from beneath and causing the coating to turn loose. some areas will come off and others will not, so you end up with a mess.
if that is the case, I would just put sealer on it, and let it ride.
and nice shop, I envy you. I cant wait to see how it turns out..!!!!!!
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
