Old 12-25-2015, 01:22 PM   #1
aotte1
12 Bolt Drum Brake Upgrade
Researching is it possible to upgrade early ( 2" shoes) 12 bolt drum brakes to the newer heavy duty brakes ( JB 5 brake option) found on later 12 bolts. Believe, the backing plates would need to be changes out. Specifications for 1979 K10, with the JB5 option for 12 bolts were provided to me by member Keith Seymore, below. Thanks Keith. Thinking of using the '79 specifications, because the front axle will be a '79 Dana 44 with the heavy duty/JB5 brake option. A more general question previously on 12 bolt brakes, has been asked in the 67 to 72 forum, by Lostmy65 in an older thread..
Les
aotte1 is offline   Reply With Quote
Old 12-25-2015, 01:25 PM   #2
aotte1
Re: 12 Bolt Drum Brake Upgrade
So directly from the '79 brake chart for a K10 JB5:
Drum - 359492; size is 283.2mm x 69.8mm
Wheel cylinder - 18004890 (diameter is 23.8mm)
Master Cylinder w/Boost - 18004252 (Delco Moraine, 28.57 mm dia); optional Bendix M/C = "KP"; booster = tandem vacuum 18003681
Combination Valve - 18002887: metering = 517 kPa, split point 1379 kPa, slope = .41
Backing plate:
Flange plate & brake asm LH = 14009889
Flange plate & brake asm RH = 14009890
The 69.8 mm is 2.75 inches. And 283.2 is about 11.15 inches.
Old 12-25-2015, 06:34 PM   #3
racecougar
racecougar's Avatar
Yep. I'm in the process of doing this myself. As you guessed, you'll need the later backing plates, but the brake offset (distance from axle flange to housing end) is the same.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-25-2015, 09:16 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Rod is correct. Just get the later model backing plates, then everything else is available at the parts store. This is a simple and effective upgrade. I might even have a spare set of those backing plates.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-26-2015, 12:57 AM   #5
aotte1
Rod and Carl thanks for the conformation, that this swap works. Sounds like you have done it with good results.
Les
Old 12-26-2015, 09:52 PM   #6
PGSigns
PGSigns's Avatar
What would you do for drums and 6 lug? be a nice upgrade on my 66. Would you use a K10 drum?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-26-2015, 10:35 PM   #7
franken
Almost all braking (75-80%) is done by the front brakes. Changing the rears is more cosmetic than functional.
Fade under continual use is another story.
franken is offline   Reply With Quote
Old 12-27-2015, 08:01 PM   #8
racecougar
racecougar's Avatar
Jimmy
Yep.
Old 12-27-2015, 11:31 PM   #9
aotte1
Jimmy,
As Rod said, will use the K10 drums.
Their may be certain Suburbans up to 91 that have this brake package also, would have to confirm this. Have a '89 Suburban "C10" complete front suspension , including brakes and crossmember that have JB5 brakes. Could check these later Surburbans and see if their rear drums are the same part number as '79 K10.
And as said above doing this as a whole brake system upgrade to the optional heavy duty "JB5" brake option, as this is a super braking package, GM designed.
L
Les
Old 01-02-2016, 08:07 PM   #10
aggie91
aggie91's Avatar
Les
I replied to your PM, just saw it sorry it took so long to respond.
Karl
Karl
The LST Challenge:
Old 01-06-2016, 10:38 PM   #11
aotte1
Continuing to research this upgrade, and found the brake shoe frame design chaned in '78. The size of the lining and drum stayed the same. However, '77 and older used a different brake shoe frame design, along with likely different internal parts too. The holes in the brake shoe frame are different between '77 and older, and '78 and up.
Still researching if their are differences in backing plates between '72 and Earlies 80s, along with C and K vehicles.
Jimmy, using K drums for 6 lugs.
L
Old 01-07-2016, 07:21 PM   #12
racecougar
racecougar's Avatar
Interesting and good information!
Old 01-08-2016, 10:27 AM   #13
aggie91
aggie91's Avatar
L
I looked into this some more too. All the parts of the brake system are the same part numbers EXCEPT for the shoes. The wheel cylinders, drums and hardware kits are all the same. Here is a pic of the backing plates with shoes and hardware that I believe are from a 1977 pickup.
Best as I can tell the '78 up shoes are missing the two smaller holes seen in the shoe frame in the pic above. All the hardware attachment holes appear to be the same. The parts store did not have the '77 shoes in stock, but had the '78 shoes and here is a pic of those:
Karl
The LST Challenge:
Old 01-08-2016, 10:37 AM   #14
SCOTI
SCOTI's Avatar
Improvement is improvement. I've done this upgrade on my 68 & 64 after realizing how easy the swap was. I would also upgrade the front brakes on a 81-87 if it only had the 1" vs 1.25" thick rotors.
Common place to find the correct backing plates is under Blazers or burbs that are getting parted out.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-09-2016, 06:19 PM   #15
racecougar
racecougar's Avatar
Finished up my swap today. Those are the "JB5" 11-5/32" x 2-3/4" drums on a narrowed '65 GM Truck 12-bolt. I used C10 rather than K10 drums, as I went to a 5 on 5" bolt pattern.
Old 01-09-2016, 06:39 PM   #16
nds1968
nds1968's Avatar
I've done this upgrade as well. Truck isn't on the road so...
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 01-12-2016, 12:01 AM   #17
aotte1
Scott, Rod, and NDS,
Thanks for the comments. Rod like the true pizza cutter wheels, had not thought of them, good idea, sort of substitute for a lift to work on underside stuff.
Les
Old 01-12-2016, 10:08 PM   #18
racecougar
racecougar's Avatar
Thanks. Those are a stand-in to help determine the final tire size.
Old 01-13-2016, 01:35 PM   #19
aotte1
Karl,
Opened box today and everything is great! Thank you.
Les
Old 01-13-2016, 03:24 PM   #20
aggie91
aggie91's Avatar
you are welcome. Glad I could help.
Karl
The LST Challenge:
Old 01-14-2016, 01:09 AM   #21
aotte1
A few photos of the backing plate, for reference. Did not see any part number on them.
Karl thought the backing plates are from a 1977 truck with a 12 bolt and heavy duty, JB 5 brake option. The last photo show a '79 brake shoes set on them, and looks like these shoes should work fine. FYI, these brake shoes were used from '78 to at least 87, maybe longer,
The difference in the brake shoe frame holes are not an issue, as Karl had speculated, for '77 and down vs '78 and up from what I see.
Les
Old 01-14-2016, 10:43 AM   #22
aggie91
aggie91's Avatar
Those cleaned up nice.
How did the new shoes compare to the one old set I sent you with the backing plates? Can you get some side by side photos of them from both sides?
Karl
The LST Challenge:
Old 01-14-2016, 10:14 PM   #23
aotte1
Karl,
Good idea, will get some photos.
Yes they are cleaning up nice, thanks.
Les
Old 01-15-2016, 10:04 AM   #24
ERASER5
ERASER5's Avatar
This is on my list of things to do, once I have the '70 back on the road. I plan to load it heavy from time to time, so better rear brakes will be an asset.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-15-2016, 11:17 AM   #25
jjzepplin
jjzepplin's Avatar
So I guess the backing plates are offset more to the inside and the shoes are 3/4" wider as well as the drums?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
