Old 04-12-2016, 09:04 PM   #1
sdwolff98
Turning Wrenches Daily
2006 and 1971 suspension experiment will it work???? who knows!!!!
Well got a wild hair up my ass and going to see if I can do a lil parts interchange between various years of chevy/gmc suspension and see what I can come up with got a free 71 complete front 3/4 ton cross member dropped off the other day from another local truck guy up this way and going to see if it is possible to fit 2006 spindles to it. Currently awaiting a spindle ball joint taper reamer to come in right now then I can see what can be done with this idea lol got the measurements from the 71 spindle and the 2006 spindle done so there is a possibility it could work just have to get the 2006 spindles tapers out to the 88-98 2 in/ft taper to see if this will be feasible
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 04-13-2016, 10:51 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 2006 and 1971 suspension experiment will it work???? who knows!!!!
Can you physically make it fit, I am sure you can but the geometry is going to be all wrong. 2" taller spindle is going to make the camber curve WAY off. Your steering arm is in the wrong location which is going to cause some serious bump steer issues.
Before spending time and money on this, buy a good race car suspension fab book and do research on suspension geometry. There is a WHOLE lot to it then just making parts fit.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-13-2016, 10:55 AM   #3
sdwolff98
Mike thanks will look into that. I was looking at the spindle not as bolting in between the control arms but in bolting it in like the 06 mounts with both ball joints mounted downwards.
Sean
Old 04-13-2016, 11:28 AM   #4
pmkrew
Looks to me like the measurements are like 1-1.5" difference and you will have to modify the LCA ball joint pocket.
pmkrew is offline   Reply With Quote
Old 04-13-2016, 12:15 PM   #5
sdwolff98
PMKrew,
thats one of the things I am seeing thats why I got freebie parts for all of this lol the only parts will need for me to buy is the ball joints and the taper reamer which is ordered..
Sean
Old 04-13-2016, 12:38 PM   #6
tinydb84
tinydb84's Avatar
The guy on this thread did it with 07 spindles: http://67-72chevytrucks.com/vboard/s...d.php?t=692590
David
Instagram: myfabguy
Old 04-13-2016, 12:40 PM   #7
sdwolff98
Tiny,
I have nearly gone blind reading all the spindle swap threads thanks for finding that for me and hoooolllyyyyyy shooot nice work there. looks like there may be something to it I like what he did with the upper control arms... so once I get the reamer in and a set of ball joints going to mount my 71 c20 cross member up where I can work on it easier and go to town. instead of building upper arm relocation mounts going to try mounting the lower a arm like the 06 factory did and see what i get love being able to experiment on stuff!!!! Never been much on reading and trying to apply it learn better by attempting and trying. Subscribed to his thread so can get up dates on any issues he might have
Sean
Old 04-16-2016, 12:00 AM   #8
beefshreadder116
beefshreadder116's Avatar
could u flip the upper balljoint upside down and run it up wards to save lowered ride height, not sure if the would be an issue with both ball joints facing up, I know with 2" drop springs my UCA are flat
Projects:
66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350.
beefshreadder116 is offline   Reply With Quote
Old 04-16-2016, 12:10 AM   #9
sdwolff98
Beef that would put the spring real a kilter in there i wont lose any ride height with both ball joints pointing down maybe a 1/2 inch at the most. Just got the taper reamer in so once its tore down cann get to work and see what i get.
Sean
