05-14-2016, 04:45 PM | #1 |
Firewall holes
What are you all doing to plug holes in the firewall? Where can you get a variety of plugs?
Thanks Also what covers this hole? Under the Wheelhouse. Last edited by 66clow; 05-14-2016 at 04:52 PM. |
05-14-2016, 05:27 PM | #2 |
The Older Generation
Re: Firewall holes
This is what goes there. They are a 7/16" bolt, 1-3/4 inches long, with a 2-1/4" integral washer on it. LockDoc .
05-14-2016, 07:03 PM | #3 |
Re: Firewall holes
05-14-2016, 09:52 PM | #4 |
Re: Firewall holes
No problem. If there is a pretty good size gap between the inner panel and the cab brace this is the type of shim that goes in there.
LockDoc
05-14-2016, 10:21 PM | #5 |
Re: Firewall holes
05-14-2016, 10:50 PM | #6 | |
Re: Firewall holes
The shims are almost a 1/4 inch thick. LockDoc
10-20-2020, 09:02 PM | #7 |
Re: Firewall holes
I see this is a old post, I have these shims and was wondering where they go!
Thanks Steve |
10-20-2020, 11:48 PM | #8 | |
Re: Firewall holes
- Sometimes they fall out when disassembling the front clip and people have a hard time figuring out where they came from..... Not every truck has them and there will usually be a different number of them side to side. Here is a picture of where the bolts with the large washer go. The "F" shims go between the inner panel and this cab support rail. The shims are made that way so you can start the bolt, then hook the shims over the bolt and they won't fall out while you are tightening the bolt.. The inner panel has a good size square hole in this location. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-21-2020 at 10:22 AM. |
10-21-2020, 07:33 AM | #9 |
Re: Firewall holes
So right here?
Sorry the last post was supposed to be a question mark not a exclamation point. Steve |
10-21-2020, 10:20 AM | #10 | |
Re: Firewall holes
Yes, that is the bolt with the big washer. LockDoc
