Old 06-21-2016, 09:02 AM   #1
The Swed
The Swed's Avatar
Best Carb and intake on a 1970 rebuild 350?
I have a Carter 650 Carb with a riser on the motor now because the mismatch to the intake is a lot. Now that I'm having the engine rebuilt I'm not sure what carb to use and if the existing intake will work. BTW the Carter 650 was free and I was trying to get the truck running to evaluate what was good and what needed to be replaced.
Thanks for the help!
Here the truck data.
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 06-21-2016, 09:06 AM   #2
Mike C
Mike C's Avatar
Re: Best Carb and intake on a 1970 rebuild 350?
Hard to go wrong with an Edelbrock Performer intake and a rebuilt Q-jet. But realistically, there is nothing wrong with the setup you have unless you are working on a max-effort performance build.
I run a Weiand 8004 on my Jimmy with a JET Stage II 750 Q-jet which used to be my favorite intake because of the price/performance but it's not a deal like it was. I like Holleys for performance application, but prefer Q-jets on trucks for the most part. FWIW, I have Edelbrock/Carters on my 350 Chevy powered inboard ski boat and the AMC 360 in my '79 CJ-5 and find them perfectly suited to those apps.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-21-2016, 02:06 PM   #3
The Swed
The Swed's Avatar
Thanks for the input Mike C
Old 06-21-2016, 02:25 PM   #4
davepl
davepl's Avatar
Performer or Performer Air-Gap (less driveable in cold weather I think) plus a Q-Jet.
As a second choice, Edelbrock AVS series (old Carter AFB).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-21-2016, 02:43 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Edelbrock performer or a performer EPS and a Holley 1850 (600 cfm), vac sec, manual choke.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-21-2016, 04:04 PM   #6
truckster
truckster's Avatar
Another vote for the Edelbrock performer and the Quadrajet. It's going to be reliable and work as well as anything out there.
truckster is offline   Reply With Quote
Old 06-21-2016, 04:39 PM   #7
57larry
Edelbrock performer intake & carb. I like the electric choke on the carb
57larry is offline   Reply With Quote
Old 06-21-2016, 04:45 PM   #8
Gromit
I've been happy with the Edelbrock Performer already mentioned; and can recommend the Quick Fuel Technology Slayer Series 600 CFM Vacuum Secondary.
I like the clear sight windows on both fuel bowls and the parts are readily available and reasonably priced. The design seems to be based on the Holleys - to the point that I have found the parts to be interchangeable. In my opinion the QuickFuel units appear to be made of a stronger alloy (for threads) than the old Holleys (which were 100% Zinc) QuickFuel are more of an aluminum.
I added a 1/2" spacer plate between this carb and the manifold for a little more clearance for the accelerator linkage.
This one is $318 delivered from Summit; and they usually have it delivered the next day for free if the order is placed before noon or so.
http://www.quickfueltechnology.com/c...600cfm-vs.html
Gromit is offline   Reply With Quote
Old 06-21-2016, 07:42 PM   #9
Gromit
quote: "I added a 1/2" spacer plate between this carb and the manifold for a little more clearance for the accelerator linkage."
Scratch that... I just remembered - the 1/2" spacer plate was to make clearance for the vacuum hose connection that connects to the brake booster - not for clearance for the accelerator linkage. This spacer was not needed on my previous Holley 4160 on the same manifold, but for the QuickFuel the carburetor base thickness is slightly thinner and so the spacer was needed.
Another thing you may consider is the Edelbrock 2101 Performer is a spreadbore and the Quickfuel (like the Holley's) is squarebore; but that 1/2" spacer plate also acts as an adaptor for spread to square.
So I think that is probably an advantage of a Quadrajet over the QF or Holley 4160; being spreadbore it matches the Edelbrock and OEM manifolds better.
Old 06-27-2016, 02:46 PM   #10
The Swed
The Swed's Avatar
Thanks for all the input! Motor pulled... time to order parts...
