Old 07-02-2016, 10:29 AM   #1
ChrisAunchman
Disc conversion kit from Captain Fab /w pics
Hey All,
Just wanted to post some pictures of my recent disc conversion. I ended up going with Captian Fabs kit that uses the D52 calipers, and astro van rotors. I am using the standard D52 caliper instead of the one that has the e-brake lever from the el durado. Big cost savings. For the e-brake I plane on utilizing a hydraulic type they use in drifting and work it off the existing lever in the cab.
Everything in this kit went together perfectly. There were ZERO issues with fitment. This is the first time I actually bought a custom kit were I didn't have to grind or knock new holes in it. This is a true bolt together kit. Calipers are perfectly centered on the rotor. COuldn't ask for a better conversion kit. I would HIGHLY recommend his kits. IN fact a guy that runs a shop near me that is a true perfectionist couldn't believe how nice this kit was. I also went with his P/S adapter plate up front and that too is really nice.
Have a great 4th!
Chris
ChrisAunchman is offline   Reply With Quote
Old 07-02-2016, 10:58 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc conversion kit from Captain Fab /w pics
I highly agree!
Captain Fab makes QUALITY products.
Keith
Convert to disc brakes.
Old 07-02-2016, 01:39 PM   #3
zach_carver
zach_carver's Avatar
Is there an exact parts list you used? As far as brake pads, rotors, and brake lines? This looks awesome!!!
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 07-02-2016, 10:09 PM   #4
ChrisAunchman
Yes, I have all the boxes at my garage I'll get the exact P/Ns for you. It was very affordable too, cheaper than rebuilding the drums and less of a headache.
Old 07-02-2016, 10:12 PM   #5
zach_carver
Thanks a lot! Was this a 6 or 5 lug conversion?
Old 07-02-2016, 11:08 PM   #6
lolife99
lolife99's Avatar
This conversion uses Astro van rotors.
So it's a 5-lug conversion.
5x5 bolt pattern.
Keith
Old 07-02-2016, 11:56 PM   #7
SierraMtns
SierraMtns's Avatar
Hey All,
Have a great 4th!
Chris
Looks good Chris. I would like to see some pictures on how you are running the e-brake setup.
SierraMtns is offline   Reply With Quote
Old 07-03-2016, 11:54 AM   #8
ChrisAunchman
Will do, it will be a bit before I plumb the hard lines, moving onto the motor and tranny next. Already have a built 700R4, so now it's just getting the block to the machine shop. It'll be something like this though.
http://www.ebay.com/itm/Universal-Ra...-/131071217760
Get rid of the handle and just work it off a cable. it goes inline with the rear brake line.
Old 07-03-2016, 04:05 PM   #9
bbbc10
Diggin The SquareLife
looks great in for part numbers
bbbc10 is offline   Reply With Quote
Old 07-13-2016, 09:40 PM   #10
Agent915
I'd be interested in that parts list as well!
Agent915 is offline   Reply With Quote
Old 07-13-2016, 10:20 PM   #11
ChrisAunchman
Will do....Hopefully will get to the shop this weekend....Been house shopping for the sat few weeks so no time to play......Researched the hydraulic brake thing and it is very do-able...I've been keeping a very detailed receipt binder of everything I put into this truck.
Old 06-20-2017, 09:28 PM   #12
Dmaxmoe
Any updates?
Dmaxmoe is offline   Reply With Quote
Old 03-24-2018, 03:40 PM   #13
jumbogem29
Any Parts list for this conversion out there.
jumbogem29 is offline   Reply With Quote
Old 03-25-2018, 12:33 AM   #14
66 C10 383
Here's the guy that makes that exact kit. I bet he'll have all the answers.
http://www.67-72chevytrucks.com/vboa...d.php?t=398352
He's got all kinds of high quality products. Very helpful and knowledgeble vendor and member that's still here to this day.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 03-25-2018, 01:28 AM   #15
Richard2112
Richard2112's Avatar
That is some nice lookin' work.
Richard2112 is offline   Reply With Quote
Old 03-26-2018, 10:04 AM   #16
68Stepbed
68Stepbed's Avatar
I used the same kit. I went for the Centric slotted and cross drilled rotors to match my Wilwoods up front. Then, I used stock front truck calipers.
Rotor part numbers: CENTRIC 12766022R, 12766022L https://www.rockauto.com/en/catalog/...hub,rotor,1896
Calipers: https://www.rockauto.com/en/catalog/...b,caliper,1704
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
