Old 08-26-2016, 03:55 PM   #1
66C10LB
Bolt sizes and thread pitch list for body panels 1966 C10
Hi. Just wondering if anyone knows where to find a list of bolt sizes and thread pitch that are used on 1964 - 1966 Chevy C10 Pickup. I am in the process of disassembly. Having a list would save me some time when I order all new bolts.
66C10LB is offline   Reply With Quote
Old 08-26-2016, 04:33 PM   #2
padresag
Re: Bolt sizes and thread pitch list for body panels 1966 C10
i think that you can order them as packages
ron
padresag is offline   Reply With Quote
Old 08-26-2016, 09:38 PM   #3
kippnidaho
kippnidaho's Avatar
I bought a kit from here it looks very complete. A little expensive but I think it is well worth it. Everything is bagged and labeled.
I think it is well worth the money considering the time and multiple trips a person would have to make to the local bolt store and getting the right lengths and washers and such.
The truck body parts should be back from the paint shop next week and the truck should start going back together very soon. So I then can give a better evaluation, but like I said the kit looks to be very complete.
http://shop.totallystainless.com/pro...vrolet&b=Truck
KippnIdaho
Twin Lakes, Idaho
1966 K10 SWB Stepside
2003 Jeep Rubicon
2011 Camaro SS Rag Top
kippnidaho is offline   Reply With Quote
Old 08-26-2016, 10:35 PM   #4
66C10LB
Thanks Padresag and Kippnidaho. Yes, you may be right Kippin, re the stainless option. I may be a bit confused....the link goes to chevrolet trucks in general....I you specify 1966 Chevrolet Truck, then there is no option for a body bolt kit. It will be good to know if you have the bolts that you need. I was thinking of more of an original look for the bolts, though. May end up going with the stainless if I can't find a similar package of bolts non-stainless.
Old 02-28-2017, 05:30 PM   #5
66C10LB
Does anyone know if the Assembly Manual contains a list of bolt sizes and threads? (Having a list would save a bit of time rather than measuring each bolt type.) It looks like original-looking bolts can be purchased through Fastenal.
Old 02-28-2017, 05:43 PM   #6
oldtrux
oldtrux's Avatar
they can also be purchased from allens fasteners,i have been really happy with them.you will need a sh*t ton of stainless flange head 5/16 x 18 x 3/4 for sure.i will try and get some other sizes for you as well......hope this helps..dan,they also have stainless flange head door bolts.dont forget stainless washers so you don't chew your paint.they also have stainless bumper bolts
oldtrux is offline   Reply With Quote
Old 02-28-2017, 05:57 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
You can buy kits that will get you close - http://www.classicparts.com/1960-66-.../#.WLXyFvIgnSg
Old 02-28-2017, 09:20 PM   #8
pimpston65
pimpston65's Avatar
some build books give the correct specs on nuts,bolts,washers and the like.
pimpston65 is offline   Reply With Quote
bolts, c10, chevy, pickup, thread
