09-17-2016, 02:43 PM | #1 |
What's a "P. Washer"
Says this in the assembly manual. Pretty sure it's just a washer, but I'd like to confirm/. That and I haven't asked a dumb question in days..............Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-17-2016, 03:15 PM | #2 |
Re: What's a "P. Washer"
You're not giving a lot of context, but "Plain Washer" is a common term, it might mean that.
09-17-2016, 04:03 PM | #3 |
Probably plain. I'm on page 843 of the assembly manual. Looks like we didn't include washers for the p-steering when we R&Red the engine some two decades ago. I'm on my way to get some hardware.
09-17-2016, 04:03 PM | #4 |
The Older Generation
I would tend to agree with davepl, since L. washer stands for Lock Washer. I have also seen P. or Pl. Washer used for Plated Washer. LockDoc
09-17-2016, 07:41 PM | #5 |
Thank you for the confirmation. Power steering is a messy job. Couldn't tell you what plugs into the fittings for temporary, so I just cut the ends off......
09-18-2016, 07:18 AM | #6 |
You are a better man than me, i would have tossed the manual long before page 800. lol !!!
i survived cancer and kidney stones, but my kids are killing me. |
09-18-2016, 09:01 AM | #7 |
plastic washer
09-18-2016, 12:54 PM | #8 |
Then you'd miss page 849, where "two" inlets run to the steering box. Confused the heck out of me.
09-18-2016, 12:55 PM | #9 |
I'm going to guess no. I don't see them using plastic washers to mount the power steering.
09-18-2016, 02:58 PM | #10 | |
You need to get the CD version. It has a search function and it works quite well. LockDoc
09-18-2016, 07:52 PM | #11 |
holy smokes, .....
09-18-2016, 10:50 PM | #12 | |
I "enjoyed" pulling the power steering so much yesterday that I swapped it for the one in the 72 today. The pump on the 71 has a ding or two and it may be leaking. Come to find out the pulley is a little stiff as well. The one from the 72, now a 71 moves freely, no leaks no dents. I don't suppose anyone rebuilds these? Has anyone bought a repro. and were you happy? These pumps have the reservoir mounted to the LH fender. Here's a repro. https://www.google.com/search?q=1972...Wlm69sn5tmM%3A
09-19-2016, 09:33 PM | #13 |
I bought one from NAPA and it has worked fine for the last 3 years. It was only the pump, you have to reuse the can.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 09-20-2016 at 07:39 AM. |
09-19-2016, 10:49 PM | #14 | |
I wonder what 3/4" hose is best to use? I can say this, I needed a piece of the hose I pulled from my 71. When I tried to clean it with hot water, it dumped what looked like corrosion non-stop. It was hose. I suspect I replaced it at some point, and it may have been for coolant. Could explain why the the pulley isn't so good.
08-19-2017, 02:57 PM | #15 |
Here's a non-explanation of a "P" washer. It has some Corvette folks stumped as well, but post 10 may give the best "non-explanation".
https://www.corvetteforum.com/forums...her-l-nut.html EDIT: Like many of you said, I think it's just plain washer. Perhaps different authors or inconsistency in description, I say this because: Page 842 in the assembly manual shows a "P. WASHER" between the stud and exhaust manifold for the power steering bracket. Page 526 in the assembly manual shows a "WASHER" between the stud and exhaust manifold for the A/C steering bracket. I see no reason to sport two different washers for essentially the same spot & purpose.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-19-2017 at 04:36 PM. |
