Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-11-2016, 10:57 PM   #1
Todd68Chevy
Todd68Chevy's Avatar
1964 C10 Long Wheel Base Rolling Chassis--- No Shipping
I have a 64 LWB frame with front and rear suspension. Frame looks straight and looks really clean above the rear axle where they rust. Trailing arms are clean also. Unknown brake and rear end condition. Believe it has been sitting a while. If it doesn't sell rolling then I will part it out. $450 Picked up in Shelburn, IN only. I don't have a way to ship or the time to figure out a way.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 12-11-2016, 11:00 PM   #2
Todd68Chevy
Re: 1966 C10 Long Wheel Base Rolling Chassis--- No Shipping
Pictures
Old 12-11-2016, 11:05 PM   #3
Todd68Chevy
More pictures
Old 12-11-2016, 11:08 PM   #4
Todd68Chevy
Few more
Old 12-11-2016, 11:35 PM   #5
Brad54
Brad54's Avatar
I'm curious about that rear end--are you sure it's a '66 chassis? The panhard mount on the rear axle is '60-'63. In '63, they went to the corporate 12-bolt, but all of them also had a Dana 44 as the optional rear.
If it's a Dana 44, it'll have "44" on the snout. (I can't see the rear cover clearly to ID it).
Otherwise, I think that rear is the '63 12-bolt.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 12-12-2016, 07:52 AM   #6
Todd68Chevy
-Brad
I do not know it is a 1966. I was told it is a 66 chassis so any information on verifying what it is would be great. The guy I got it from said he bought it as is to put under a truck that he had wrecked but ended up finding a complete truck instead so did not need the chassis. I mainly know the 67-72 trucks and still learning on the 60-66 trucks. The guy I got it from said it was a 66 and I knew the front looked correct because of the control arms and not the torsion bars. I do not want to sell something for what it is not so any help would be great. I can get more pictures when I am home in the daylight. I thought it looked like a 12 bolt but did not really pay attention to it because I did not know there were options. Thanks for the information.
Old 12-12-2016, 10:29 AM   #7
mibo
If you get ready to start parting it out, I would like the motor mounts
Good luck
Mike
mibo is offline   Reply With Quote
Old 12-12-2016, 11:54 AM   #8
Brad54
Brad54's Avatar
As far as I know, the '63-'66 chassis is the same, so you shouldn't have any problem regardless of the rear end.
The panhard bars on the '64-'66 are the shorter ones that go to a boss on the top of the axle housing, while the '63 had a longer bar that connected to a bracket on the axle tube, the same as the '60-62.
Mounts, width, bumpers, everything else should be the same, so you shouldn't have any problems.
-Brad
Old 12-12-2016, 01:40 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
-Brad
Where the panhard bar mounts to the frame is different on the 64 vice the 65/66. This frame looks like a 64's.
http://67-72chevytrucks.com/vboard/s...d.php?t=550400
Old 12-13-2016, 06:23 PM   #10
Todd68Chevy
-Brad
Ok, Thanks
I will check that out. Thanks
Good luck
Mike
They look like the 67-72 250 six cylinder stands and if they are then I have several of those extra that I would sale. I will see if I can verify if they are the same or not.
Old 12-13-2016, 08:52 PM   #11
mibo
you could be right about the engine perches being for a 6 cylinder - they looked to me like they were for a V8
If you have some for a V8 I am interested
Mike
Old 12-13-2016, 10:14 PM   #12
Todd68Chevy
Mike
In the 67-72 trucks the v8 and I6 are different but I was told that in the 66 and earlier the v8 & I6 are the same. I am just not sure if the 66 and earlier are the same as the 67-72 I6 stands. If you can understand what I am saying. These are in the V8 location so I would say these are correct for the 66 and older V8s. I will see what I can find out.
Old 12-13-2016, 11:42 PM   #13
mibo
Thanks for checking into this
We will see what turns Up
Mike
Old 12-14-2016, 10:14 AM   #14
GMCNUT
GMCNUT's Avatar
Longbed frames can be tough to move - If it comes down to parting it, I want the transmission shift linkage bracket off the drivers frame rail - the one with the ink pen shaped spear sticking out from it....held in by two rivets.
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 12-17-2016, 01:48 PM   #15
Todd68Chevy
-Brad
-Brad
Thanks guys. Sounds like this is a 63 or 64 chassis. Here are a few more pictures of the rear end and panhard mount.
Old 12-17-2016, 01:51 PM   #16
Todd68Chevy
Good luck
Mike
They look the same to me. Here is a pair I have for $35 plus shipping.
Old 12-17-2016, 01:52 PM   #17
Todd68Chevy
I will let you know.
Old 12-17-2016, 07:31 PM   #18
60-66
60-66's Avatar
To narrow it down a little more Todd , its a 1964 frame. 1963 did not use a frame bracket for the automatic shift linkage .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-17-2016, 10:15 PM   #19
Todd68Chevy
Thanks, It is great that we could figure out the correct year. Thanks everyone.
Old 12-23-2016, 10:23 AM   #20
Todd68Chevy
Ttt
Old 02-06-2017, 08:18 AM   #21
Todd68Chevy
Still available
Old 07-28-2017, 06:35 AM   #22
Todd68Chevy
Sold
