Old 01-03-2017, 05:21 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
AAW Severe Duty Complete Car Wiring Harness 510564?
It's designed to mount in any environment. I was thinking of using it under the hood so you don't have to crawl under the driver side dash for access to fuses. It would be used with an LSx swap and would mount the ECU next to it as well... Has anyone moved the main fuse block from the factory location? I was thinking a smoothed firewall, so it would replace the heater box in the engine bay.
I like the modular design of this fuse panel...
Rich
1972 K5 Blazer CST Click HERE
Old 01-03-2017, 08:24 AM   #2
Bigdav160
Bigdav160's Avatar
Re: AAW Severe Duty Complete Car Wiring Harness 510564?
Nice looking kit. A little on the expensive side.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-03-2017, 10:32 AM   #3
reaper71
reaper71's Avatar
Hey Rich, I just installed one of these kits in a customers 78 FJ
It's a really nice kit...there is however a few draw backs.
1. (buy the weather pac crimpers first!) it is a must for crimping your ends that go into the connectors.
2. all of your ignition connections are a bit harder to do and are limited!
3. make sure you have easy access to the plugs (are a little hard to unplug)
Me and my Dad (oldman3) have used several AAW kits and usually go with the standard style (run your own wire to the panel and connect) aka. hwy 22 series and they work great.
One thing I can say about the kits from them is they do have detailed instructions and are of very good quality just my 2cents
Mark..
reaper71 is offline   Reply With Quote
Old 01-03-2017, 11:30 AM   #4
solidaxel
solidaxel's Avatar
Kinda of what I was thinking!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-04-2017, 07:40 AM   #5
mcmlxix
mcmlxix's Avatar
* I have crimpers
* what's limited? I want RFID and push button start...
* I was thinking smooth the firewall and mount it there
Mark..
do you have any pics of the install? did you put it back under the driver side dash?
Rich
Old 01-04-2017, 10:10 AM   #6
reaper71
reaper71's Avatar
I do have shots of it on the (FJ Build) I ended up putting it inside the glove box do to limited space and the owner wanted it kinda hidden.
Don't get me wrong it is a Very nice kit!
It does however take a bit more planning when installing this kit because of how it goes together (plugs etc) unlike the normal HWY 22 series (strip the wire and put it in its place on the panel) These are just things I noticed installing this kit vs. the 22 series (again just my opinion)
Mark...
Old 01-06-2017, 05:47 PM   #7
FAKKY
I was originally going this route ....... think I am going to go the rear mount Rebel Wire kit ........ can mount anywhere in truck. Cheaper too.
FAKKY is offline   Reply With Quote
