![]() Join Date: Mar 2014
What Brakelines Do I Need?
Just did a disc brake conversion from CPP for my 70 C10, currently has no master cylinder and no brake lines in the truck. What do I use? Should I just go to Autzone and get a disc/drum MC from 72 and order pre bent 72 brake lines from Brothers? I would probably also buy the prop valve from Brothers, Classic Parts or POL. I'm just looking for a direct bolt up no worries type of set up. thanks in advance.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
#2 | |
The Older Generation
Re: What Brakelines Do I Need?
![]() LockDoc
I'm fine with a little bending to fit but I want to find a formula that isnt too complicated. Something simple and relatively inexpensive. Do you have any suggestions?
#5 | |
http://www.ebay.com/sch/i.html?_from...+line&_sacat=0 A lot of people on here have posted about problems with the pre-bent stuff. LockDoc
Will the Nicopp lines take a double flare that is recommended for brake lines?
Watched a U-Tube video, using Nicopp, but he was not using a double flare on lines for a Mustang. |
![]() Join Date: Jun 2009
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
![]() Join Date: May 2012
I would recommend for you to get the pre bent from inline tube. I bent every line on my truck, and I can flare ends. But if you have no experience you may struggle with ugly bends and leaks. What you can do is use all straight line pre flared. Start your layout at the wheels and end at the valve under the master. Then you can just coil the excess there and not have to flare. So my basic advise is make the layout with cloths hangers, measure, then get some lengths of straight line pre flared so you don't have to flare ends.
I think if you call a company like inline they can help you out with MC and prop. On that mustang video you watched, if he was not double flaring 45, he was not using an OEM connection. You will be double flaring at 45. If you are going OEM.
White K20 |
#9 | ||
LockDoc
I did all my own, and it was really my first real attempt. It turned out great, except for the bruises on my hips from bending stainless, which is tough.
If I were doing copper brass or mild steel I would DEFINITELY do it myself, though stainless is a tougher call. I had the Mastercool hydraulic flaring tool, and recommend it. I don't think I'd want to do a whole truck with a manual flaring tools, but maybe softer metal would be OK... So if you can buy/rent a decent flaring tool and you're using a softer tube, go for it! If in doubt, look up Right Stuff detailing, they had the best stuff when I looked. The pre-bent stuff is only going to fit C10 regular bed, though... 3/4T, anything like that and you're on your own like I was.
Post Whore
![]() Join Date: Feb 2016
My vote is for the nickel copper tubing. It has been used for decades in Europe on high end cars. Only recently got approved for use in the US. Very forgiving to work with. Less prone to corrosion than steel lines. Can be polished to a high luster. And now days it is easy to find so the price has come down. I wouldn't use anything else. Over the years I have tried different prebent tubing companies and learned their idea of prebent to fit and mine are different. One trick I use is to make a practice piece out of some solid conductor copper wire. It will make those tricky pieces easier and you won't waste any tubing. Start with the rear axle tubes as they are shorter and easy to get at. Buying an all in one bender will work "OK" but you will get much better results with a bender sized for the tubing your working with. For your truck you will use 1/4" tubing for the lines from the master cylinder to the Tee's. Then it should change to 3/16" after that. At least that's what my 67 did. There is some more info on page 8 of my Working Man's Burban thread (The WMB) Troll around some there is lots of info here, even if you just look at pictures to confirm fitting sizes and tubing routes.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#12 | |
Hey doc, how do you cut your lines, do use a pipe cutter or saw and file? On tougher steel I like to cut and file. I have a piece of flat steel with holes drilled into it. I lay this on the flaring clamp with line protruding so I can file square without marring my flaring tool. Then I chamfer a bit around the edge. Just thinking I might pipe cut if the Nicopp is a bit softer. I have several small pipe cutters I use for copper plumbing. But I'm paranoid about square cuts.
White K20 |
Tags |
brake lines, master cylinder, pre bent |
