03-26-2017, 06:19 PM | #1 |
'70 C10 Temp Gauge Max Hot, Why?
1970 C10, 402 engine, with gauges. Temp gauge was max cold when I got the truck last summer.
I put in a new temp sensor, new OEM temp gauge, new instrument panel bulbs and bulb holders, and new instrument panel printed circuit board. Now temp is always max hot. I did continuity check on wire from temp sensor to passenger-side post on temp gauge and it checked good. Got 12V on drivers side post of temp gauge. I'm stumped. Any ideas? |
03-26-2017, 06:34 PM | #2 | |
The Older Generation
Re: '70 C10 Temp Gauge Max Hot, Why?
There are two senders for our trucks. One is for gauges and one is for lights. Are you sure you got the right one? I will see if I can find pictures of the difference. LockDoc
03-26-2017, 06:34 PM | #3 |
Msgt USAF Ret
Your sender wire is grounded someplace, or the sender is no good. Check the terminal where the wire goes on the sender to the sender body with an ohmmeter for around 200 ohms cold. Take the wire off the sender first to see if the gauge goes to cold.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-26-2017, 06:39 PM | #4 |
just because a part is new does not mean it will work, new parts are bad all the time, the sender could be bad.
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
03-26-2017, 06:45 PM | #5 |
Here are some pics. Temp sensor is on an Edelbrock RPM Airgap intake manifold.
03-26-2017, 06:48 PM | #6 |
with the temp sensor wire off the sensor the temp gauge stays at max hot, ignition switch on and off.
03-26-2017, 06:53 PM | #7 |
with one lead on temp sensor top and the other lead on temp sensor base, ohms are 171, engine is mildly warm still.
03-26-2017, 06:56 PM | #8 |
So it appears I've got a ground somewhere. What puzzles me is I checked continuity from temp sensor wire end to the gauge and continuity checked good. Could that happen if there was a ground somewhere?
03-26-2017, 06:58 PM | #9 |
Shouldn't your sending unit be on the side of the DS head? On a related note, where can a guy get the connector for the sending unit?
03-26-2017, 06:59 PM | #10 |
My instrument panel connector matches this schematic
03-26-2017, 07:02 PM | #11 |
https://www.summitracing.com/parts/PCO-5665PT
for the sending unit wire connector. No one in Las Vegas had them. It's on order, haven't received it yet, Summit told me that is what fits. |
03-26-2017, 07:10 PM | #12 |
Who Changed This?
The gauge itself could be hosed. That's what happened to mine in identical circumstances. I doubt that there is a short in the wire, since the sender for a gauge is a thermopile that sends power to the meter. A short would leave the gauge indicating a lower temperature, as less power would be seen by the gauge.
03-26-2017, 09:01 PM | #13 |
Msgt USAF Ret
If your gauge reads full hot with the key off then your gauge May be bad. If your sender wire is pinched and grounded, it will read continuity end to end even through the ground.
you should unplug the cluster plug and if the wire is shorted to ground then the gauge will return to cold unless the short is in the cluster body. Some of these gauges will stay the same when the power is off as they read while the key was on. The needle on the temp gauge would stay where it's at until the ground is removed. That would explain why it reads past hot all the time.
01-30-2024, 07:23 PM | #14 |
Old thread but my temp gauge is pegged just like in post 5.
I have all new wiring harnesses, gauges, printed circuit, "everything." With temp sending unit wire disconnected and battery disconnected, still pegged. From what I am reading, gauge must be bad??? Sucks, if that's the case because pulling the cluster is bummer as stuff always ends up worse (in my experience). After putting the whole truck together, only this gauge and dome light don't work so I guess I am lucky (for now). |
01-31-2024, 12:16 AM | #15 | |
Did it ever register anything else? I would hook it all up, turn the key on and rap on the cluster in that area (lightly) with the side of my fist to see if it is just stuck. .
01-31-2024, 01:40 AM | #16 |
It was on cold when I installed the dash and set that way for months. After installing all the wiring and hooking up the battery, I noticed it was on max when I did my firing test.
As suggested, I went out the the truck with the intent of giving the gauge a litlle bang with my knuckle from the backside. The battery and sending unit still disconnected, reached under the dash and touched the temp terminals with my fingers and heard "spring/click" sound. The needle popped back to the cold side. ????? Go figure. Me being a ground??? Luck?? Didn't even tap it. Will try hooking everything up in the morning and fire it up to see what happens. But for now it is on the cold side where it belongs. A victory for now. Last edited by CKfan; 01-31-2024 at 01:45 AM. Reason: add info |
01-31-2024, 10:43 AM | #17 |
Junior Member
Had a similar thing happen once after I changed the cab on a 72 pickup.
Temp gage would go full hot when key was in the start position. Problem went away after I installed the ground straps from engine to cab and from cab to frame. Was the gage carrying the full ground to the cab? I don't know. |
01-31-2024, 01:20 PM | #18 |
Hooked the sending unit wire back up, the battery, turned the key to on and quickly pegged the needle again. Reversed what I had done but this time touching the back of the terminal and tapping on it had no effect. Still pegged.
Bad ground seems likely but everything else on the cluster works. I have two ground straps to the cab already, as I know to use lots of grounding points on these trucks. Because the dome light doesn't work also, I will take off and re-tighten the ground straps to see what happens. |
01-31-2024, 01:50 PM | #19 |
In other GM forums, guys have had issues with the currently available sending units, as the resistance values are not the same as original. Only AC NOS or Lectric Limited reproductions are correct to get a somewhat accurate reading.
https://www.lectriclimited.com/catal.../category/734/
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
01-31-2024, 02:21 PM | #20 | |
01-31-2024, 02:36 PM | #21 |
Post Whore
The circuit works so when the wire is off of the sensor the guage should read low. When the wire to sensor is grounded to the block the guage should peg high and it should be some where in between when hooked to the sensor. The key must be on for these tests.
If you get no action then I would check the continuity of the wire from the sensor to the guage plug at the circuit board disconnect the sensor from the wire for this. If you have good continuity then I would pull the guage. It is possible to just remove the temperature guage pair from the rest of the guages. Possible not easy.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-31-2024, 02:51 PM | #22 |
Cold tested per above .806
01-31-2024, 03:29 PM | #23 |
Hmmm I took off both nuts and washers from the printed circuit to gauge terminals and the gauge popped back to cold. I put it back together, watching the needle as I slowly turned the nuts back on. Had the key on while doing it. Gauge started working perfectly but as I turned the nut a bit tighter, pegged hot. So I loosened the nut (barely snug) and it now works as it should. Although something is not right, it works. Would be hard to believe the nut would have to be sloppy loose to work.
Should the lock washer and nut be right against the printed circuit like in photo? Thanks for the help. Enough to drive a guy crazy |
01-31-2024, 04:35 PM | #24 |
It could be that the gauge is attached crooked or off-center on the mounting plate which could cause one of the posts to short out on the mounting plate. I've seen that issue before.
01-31-2024, 05:04 PM | #25 |
Thanks. Amazing how many different thinks can go wrong or possibly wrong with one system or piece.
