Old 04-11-2017, 02:38 PM   #1
Cow.kllr
1972 c10 body swap t56 AWD ls2 build
Starting a new build thread. I got a 1972 c10 swb that I'm going to put the body on a frame from a 2008 trailblazer ss. It will have the ls2 with a t56 and be AWD. I've already started a build thread over on tbssowners.com. http://www.tbssowners.com/forums/mem...wap-build.html
I will post some pics of stuff I have done already and more as I progress. I work alot so the posts might go quiet for a while but I update as soon as possible.
Cow.kllr is offline   Reply With Quote
Old 04-11-2017, 04:28 PM   #2
Cow.kllr
Re: 1972 c10 body swap t56 AWD ls2 build
Here some pics of it so far.
Old 04-11-2017, 04:38 PM   #3
Cow.kllr
Trying to figure out how too
Old 04-11-2017, 04:42 PM   #4
Cow.kllr
More
Old 04-11-2017, 06:33 PM   #5
keetonb25
I'm in
keetonb25 is offline   Reply With Quote
Old 04-11-2017, 07:15 PM   #6
72 tigger
72 tigger's Avatar
Sounds like a great idea- what's the wheelbase difference?
72 tigger is offline   Reply With Quote
Old 04-11-2017, 10:06 PM   #7
Cow.kllr
The c10 is 2 inches longer
Old 03-08-2021, 10:51 PM   #8
Cow.kllr
I got a plan to get the cab mounted soon. I made some simple inner rockers out of 1/8" plate steel. Built a tube frame structure for the cab floor support. I'm gonna connect the 2 and build some mount brackets to weld to the frame.
Old 03-08-2021, 11:09 PM   #9
Cow.kllr
Well, I didnt know it has been that long since I posted anything.i will post some update pics. I have the trans crossmember built. Frame lengthened 2". Doors and outer rockers mounted and aligned decent.
There is more detail on the tbss website link in the first post.
Old 03-08-2021, 11:51 PM   #10
Leonard60
Subscribed very interested in this project.
Leonard60 is offline   Reply With Quote
Old 03-09-2021, 09:20 PM   #11
sawmilldmax
Nice work and a great idea. Forced induction would be a pleasant accessory on this build.
sawmilldmax is offline   Reply With Quote
Old 03-09-2021, 09:55 PM   #12
Gigem
Gigem's Avatar
4 years later...
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 03-09-2021, 11:56 PM   #13
Cow.kllr
Originally Posted by Gigem View Post
4 years later...
Yeah, 😢
Life...
Old 03-10-2021, 12:01 AM   #14
Cow.kllr
Inner rockers are done so far. Lower fender bolt installed
Old 03-10-2021, 07:07 AM   #15
72 tigger
72 tigger's Avatar
Making progress!
71 C10
72 K20
72 K10 Super
Kirk
Old 03-15-2021, 06:43 PM   #16
Cow.kllr
I had a couple hours today and go the core support mounted. I had to do a bunch of measuring to make sure it got in the right spot. Wheel spacing, firewall spacing and room for radiator all look good.
The rest of the cab mounting process will be based of this. I did multiple searches on the internet and found that the front wheel centerline to the core support mounts on a c10 is 21.5 inches. So I measured from the tbss front wheel centerline and that's how I got the location to drill the wholes. I should have taken a pic of my contraption I had set up to get that measurement. It was kind epic/wonkey, but it worked.
Once I get the cab tacked in place where it will set, I will set the bed on to make sure it will work and then weld everything in place.
Old 01-31-2023, 11:29 PM   #17
Cow.kllr
Small photo dump. I've been spending alot of time on the fire wall. Got the flange made and welded in. I got the firewall cut to size. It will be cut and trimmed more. Got my pedals fabbed up. Waiting on the pedal pad rubbers to come in the mail. There is more to be done on the pedal bracket, but I got to get the firewall set in place first. I'm gonna attempt to emboss a design on the firewall by hand. I've gotta get some mdf board and get a design figured out. I was able to cut the temporary cab support out. I figured I was far enough along to do that. I think that's about it for now.
Old 01-31-2023, 11:31 PM   #18
Cow.kllr
I realized I haven't post I much progress as I've got done so I'll post more
Old 01-31-2023, 11:36 PM   #19
Cow.kllr
More pics
Old 01-31-2023, 11:39 PM   #20
Cow.kllr
And more.
Old 02-01-2023, 12:40 AM   #21
LockDoc
The Older Generation
LockDoc's Avatar
Looks like you are making some good progress on it. We now have a forum for projects and builds and I will move your build thread over there.
LockDoc, Moderator
Leon
Old 02-01-2023, 06:53 AM   #22
72 tigger
72 tigger's Avatar
Wow, you’ve been doing a lot of fabrication. Keep plugging away
71 C10
72 K20
72 K10 Super
Kirk
Old 02-01-2023, 08:09 AM   #23
Cow.kllr
LockDoc, Moderator
Old 03-26-2024, 02:27 AM   #24
Cow.kllr
I've got alot of updates. ive been busy and trying to knock out a bunch of stuff.
I built my own custom bed floor out of 1" square tubing. pics are the bed floor mounts and the risers I built to support the bed
Old 03-26-2024, 02:29 AM   #25
Cow.kllr
I ended up back halving the rear frame because I'm anal.
