05-18-2017, 09:02 PM | #1 |
Cheap factory Tach on E B A Y
Factory tach for $1
http://www.ebay.com/itm/1964-1965-19...dZBQnE&vxp=mtr |
05-19-2017, 01:02 AM | #2 |
Post Whore
Re: Cheap factory Tach on E B A Y
Starting Bid was $1.....ends in 5 days...we'll see how far up it goes from there!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-19-2017, 01:11 AM | #3 |
And this guy has a factory 6 cyl?! tach but he wants a payment on his mortgage for it. $480. Too rich for my blood but man I wish I had an original 6cyl tach. First one I have ever seen. http://www.ebay.com/itm/252941138108...%3AMEBIDX%3AIT
05-19-2017, 08:34 AM | #4 | |
Moderator
05-19-2017, 10:18 PM | #5 |
I wonder what's different between '60-'63 and '64-'66?
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
05-19-2017, 10:28 PM | #6 |
But Found Her 25yrs Later!
The older one takes some kind of converter to be used.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-19-2017, 10:30 PM | #7 |
Correction.... Transmitter:
http://67-72chevytrucks.com/vboard/s...highlight=tach
05-21-2017, 10:28 AM | #8 |
That's it? They otherwise bolt into both instrument clusters the same?
-Brad
05-21-2017, 07:40 PM | #9 |
Yes, the 60 through 66 factory tachs all bolt into the instrument clusters the same way. And the face plates look the same too.
As LostMy65 said, the early ones use an external transmitter box that houses all of the control electronics ... the part in the dash is just the meter movement. I believe the change to the newer style (with the control electronics built into the tach assembly) occurred in 63 so the tach listed on eBay would be correct for 63-66. And it would also fit a 60-62 instrument cluster. |
05-22-2017, 08:44 PM | #10 |
Boy, it's not cheap anymore! That's allota coin to pay for a busted tach.
-Brad
05-23-2017, 10:21 AM | #11 |
I have several of these tachs , usually its just some dirt that worked its way into where the needle pivots. A good cleaning and I bet its good to go . Thats a $350.00 tach if the guy knew how to fix it.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
