pancaked crossmember problem
I have recently put pockets in my lower control arms with bags, im running d2600 bags and my frame was 3 inches off the ground. So i decided to pancake my crossmember 1.5 inches to get a little lower. Well i bolted it all back together and it only dropped 1/2 inch. I know the control arms will hit before the frame but my mind is boggled as they are still an inch off the ground. Am i missing something? Im guessing with the motor and everthing in it it will drop some more. Any help is appreciated. Thanks
![]() Join Date: Jul 2010
Re: pancaked crossmember problem
pictures would help
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
Did you clearance for the steering? Maybe that is what is holding you up.
Pics would help a ton. |
I notched the frame for steering
not sure why my pics are sideways
As far As my thoughts about this......Pan caking a crossmember won't change a thing to suspension height.....just drops front body height....
how do you figure? It moves the entire front suspension 1.5 inches.
Posted via Mobile Device |
Looking online those bags are about 2.8 fully compressed. What do yours measure?
![]() Join Date: Jan 2011
I agree with Sik66. Pancaking changes just the frame height and not the crossmember. It does move the front up 1.5" in relation to the frame. I does not change any of the geometry of the front suspension to allow it to go lower.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Are you upper ball joints binding? Many people have to pie cut the uppers to decrease the ball joint angle.
Loosen you upper ball joint and see if it gets lower.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#13 |
How you go?.....get it sorted?
