Old 06-28-2017, 12:48 PM   #1
Carl Spangler
Carl Spangler's Avatar
Need larger radiator for 71 C10 with L6
Greetings
My 71 C10 with 250 needs a new radiator.
It has the original size (2 core?) thin radiator. If I'm going to replace this radiator I'd like to add some capacity. What size would fit in this truck? Would be nice to replace with a 3-4 core radiator.
Here's the radiator that's currently in the truck. I'm assuming it's either the original or an original-replacement.
The two top tank hold down clamps are spaced 26.5" center-center.
thanks
Carl Spangler is offline   Reply With Quote
Old 06-28-2017, 02:27 PM   #2
Carl Spangler
Re: Need larger radiator for 71 C10 with L6
Are the plastic tank and aluminum core radiators decent or junk?
Edit: Did a quick search and it looks like plastic tank radiators are pretty much standard now.
I'll probably order an NPD radiator.
Old 06-14-2019, 06:49 AM   #3
bubbasimms
Hey Carl,
I know this is a year old post but what did you end up doing to solve your radiator issue. I am now in the same boat you were a year ago and looking for a radiator.
bubbasimms is offline   Reply With Quote
Old 06-14-2019, 07:54 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by bubbasimms View Post
Hey Carl,
He hasn't been on since 10/22/18 but you never know when someone will pop back in......
Just a heads up.
LockDoc
Leon
Old 06-14-2019, 08:14 AM   #5
Hey Carl,
Just get a 3 or 4 core radiator for this year truck. You will need the corresponding hold downs and lower saddles. They are found on the parts board pretty regularly
Old 06-14-2019, 09:20 AM   #6
Carl Spangler
Hey Carl,
I bought a 3 core all metal radiator. I can't remember the vendor name but the tag on the top indicates VCCS H201-2. It was just under $200 including shipping.
I also installed an overflow tank and a 10# cap. The "low pressure" cap allows the coolant to partially fill the overflow tank every time the engine is run warm-hot. When the engine cools the fluid is sucked back into the radiator/engine. This discharge-refill process eventually fills all of the air voids in the engine. At that point there is maximum heat transfer from the hot parts of the head into the coolant system. The whole coolant system works fabulous now and the low pressure (10#) cap means the system isn't being stressed with high pressure. Works GREAT!
Old 07-04-2019, 04:55 PM   #7
Carl Spangler
Quick update after another minor mod:
I switched out the 10# radiator cap to a 7 pound Stant 10328 Lev-R-Vent cap. With the new 3 core radiator this truck rarely hits 190 degrees and the 7 pound cap with overflow tank works perfecto!
Old 07-04-2019, 10:51 PM   #8
Barnfind46
Barnfind46's Avatar
Glad to see it all worked out!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 07-05-2019, 01:10 AM   #9
bubbasimms
Thank You Carl Spangler for the reply. Great to hear its working out good for you.
Old 07-05-2019, 08:51 AM   #10
old51sedan
old51sedan's Avatar
Carl,
Glad this all worked out for you. I'm also in the same boat, I need a radiator for my 6 cyc. I'm adding Air to the truck, mine has a radiator shroud, I see yours didn't. Do you know what the over flow tank came off from, looks like it belongs there.
old51sedan is offline   Reply With Quote
Old 09-16-2020, 11:46 PM   #11
Carl Spangler
Originally Posted by old51sedan View Post
Carl,
Here's an eBay link to the overflow tank I used:
https://www.ebay.com/sch/i.html?_fro...85692&_sacat=0
Old 09-17-2020, 02:41 AM   #12
gmc684x4
From reading up some aluminum rads can cool better from being able to have larger wider tubes then old 4 core copper rads
Stock caps are 15 psi with overflow tank i would be inclined to look for a cap at 15 psi with overflow capability
Places like rock auto list all aluminium rads for our trucks
gmc684x4 is offline   Reply With Quote
Old 09-17-2020, 08:54 AM   #13
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Need larger radiator for 71 C10 with L6
Best radiator you can buy for the money and it's all aluminum no plastic. I have one in my 71 C-10, 67 Ramp truck, 64 SS Impala and had one in the 56 Bel Air. Not one problem out of them and they run cooler than the stock ones.
https://picclick.com/68mm-Aluminum-R...850583294.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-17-2020, 09:06 PM   #14
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have heard that 13 PSI is normal for trucks w/o A/C and 16 PSI for trucks with A/C, but I ain't the Pope, so I could be wrong. The higher pressure cap raises the temp needed to boil over.
I put a wider V8-type radiator in front of the 292 L6 in my '68 C/10, when I found the L6 width was NLA.
Mine's still a copper/brass type. Do you have to use the Orange antifreeze in an aluminum radiator?
Old 09-17-2020, 11:52 PM   #15
Carl Spangler
In my continuing cooling fine tuning I just swapped out the 195 degree F thermostat for a 180 degree. The cooling system is working GREAT with the 180 degree thermostat, 7 lb radiator cap, and reservoir.
Old 09-17-2020, 11:59 PM   #16
HotWheelsFan
HotWheelsFan's Avatar
Might try a body shop that restores vintage vehicles...
By chance my friend (body man at a resto shop) got me a new rad for free. he had 3 of them from resto jobs done in the past 6 mos. to year...
Mine was a 1970 HD brass $250 retail, $100 used easy. Free...
Shipping is no fun, find local...
Bob
HotWheelsFan is offline   Reply With Quote
Old 09-18-2020, 12:38 AM   #17
'68OrangeSunshine
I just installed a reservoir of the '78 Nova type in my '68 Stepside. Looks great. However, the overflow outlet on the radiator neck points hard right, and with a new battery tray bracket, there's not enough room to hook up a a hose to the reservoir, the battery's in the way.
[Sorry now ''After'' picture yet.]
Old 09-18-2020, 08:09 AM   #18
68panelman
68panelman's Avatar
I'm also liking your overflow, except the ebay link brings me to their homepage?, Anymore info is greatly appreciated
68panelman is offline   Reply With Quote
Old 09-18-2020, 01:20 PM   #19
Carl Spangler
Here's one vendor (multiple to choose from for the same part):
Note: This is not an EXACT fit as I had to gently bend the tabs at the bottom to conform to the inner fender well. It's also a fairly tight fit/clearance to the battery (see pic above).
https://www.ebay.com/itm/1978-1988-M...AAAOSw2S1fXpMw
You will need a cap also:
https://www.ebay.com/itm/New-Genuine...sAAOSw3Q9db9vY
I finally found the vendor for my replacement radiator. This link is for a 3-row for a 1971 with a 6 cylinder engine:
https://www.nationalpartsdepot.com/r...s-12786-1.html
Old 01-28-2021, 11:13 AM   #20
Dad's72
Dad's72's Avatar
Is there any benefit to having the original radiator fixed? I called a local radiator shop in town and they said they would do a full clean and then pressure test to fix any leaks. They said it will be like new when they are done with it.
I think it would look better than a shiny aluminum radiator in a 50 year old truck. I guess my logic is, if it worked for this many years shouldn't it be okay for the same stock motor in the truck?
Dad's72 is offline   Reply With Quote
Old 01-28-2021, 11:49 AM   #21
Sheepdip
Sheepdip's Avatar
Don't know about Texas but here in Kalifornia the EPA has basically put the old style radiator repair out of business. No more acid baths to properly clean the cores, tanks, etc.
That's why all my classics are running Champion Aluminum Radiators, zero problems including one that's been in for 20 years now.
Otis my avatar has a Champion Radiator w/electric fans guaranteed to cool up to 1000 HP, I have no where near 1000 HP, but I got lots of cooling. 100+ degree days with A/C on in town/slow traffic no problems whatsoever.
Sheepdip is offline   Reply With Quote
Old 01-28-2021, 12:16 PM   #22
Carl Spangler
The copper 3-row I put in my L6 truck looks virtually identical to the original 2-row. When hauling heaving loads up long hills the 2 row couldn't keep the engine temp stable. The new 3-row keeps the engine temp very stable under similar heavy loads.
1971 SWB step side: Original NM Forestry and then NM Fire truck
Old 01-28-2021, 12:52 PM   #23
68panelman
68panelman's Avatar
[QUOTE=Carl Spangler;8810044]Here's one vendor (multiple to choose from for the same part):
https://www.nationalpartsdepot.com/r...s-12786-1.html[/
Thank you Carl for the links, I was not receiving any emails for this thread for some reason?,... Until today? Strange
