07-19-2017, 04:48 PM | #1 |
Best way to clean this
What's the best way to clean those steering wheel
07-19-2017, 04:50 PM | #2 |
Re: Best way to clean this
I used tire shine on mine, works decent
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
07-19-2017, 05:02 PM | #3 |
Best way? A great source or two would say:
Clean it. Simple green should work, then wipe it off. Sand the scratches out. Depending on scratch, start at 400 & work your way to 3000 o so. I'd be real careful with any 400. Take your time. Carefully polish with white rouge & a soft flannel buff. Treat it. Admire your wheel. I've only gone so far as sanding. Turned out nice.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-19-2017, 05:07 PM | #4 |
GoJo Cherry with pumice works very well.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
07-19-2017, 05:23 PM | #5 |
I assume this is the same wheel you said was blue paint on a black wheel? Do you want to keep the blue paint while removing the discoloration, or are you looking for methods to prepare for new blue paint?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
07-19-2017, 05:53 PM | #6 |
I just wash it looks good to me what
You think |
07-19-2017, 05:56 PM | #7 |
I'd probably go with simple green to get the dirt knocked off.
My body guy gave me a good trick to polish mine. Make a paste with Comet and a little water. Rub it out with a rag and you'll be surprised how nice it comes out. If you have deep scratches, you could use 2000 grit sandpaper before the Comet.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
07-19-2017, 06:16 PM | #8 | |
07-19-2017, 06:43 PM | #9 |
I need to get a button where the best place I'm in ga
