07-19-2017, 08:56 PM | #1 |
Help me find np205 output shaft gaskets
I've been going nuts trying to find a front output shaft bearing retainer gasket for my NP205. Can somebody please give me a part number? One would think that rebuild parts would be plentiful for such a common transfer case, but apparently not.
Can I just throw some RTV in there? Posted via Mobile Device |
07-19-2017, 09:04 PM | #2 |
Re: Help me find np205 output shaft gaskets
The gasket for the front output came in my bearing & gasket kit (BK205GDM, Transparts Warehouse, Amazon)
You can seal it with RTV, I like the gasket though. |
07-19-2017, 09:11 PM | #3 |
The Older Generation
Go to an auto parts store, get some gasket material and make one. LockDoc
07-19-2017, 10:10 PM | #4 |
Post Whore
These are my go to guys for transfer case and manual tranny (SM420) stuff.
https://www.novak-adapt.com/catalog/...er-case-parts/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-20-2017, 12:52 AM | #5 |
I've got a bunch of extra stuff laying around, I'll check in the morning and see exactly what I've got. Just the 1 piece with the 4 mounting holes? what else?
Try not to use just RTV, there is a clearance issue built into the retainer and the gasket thickness. Using just RTV could possibly lead to cracking of the aluminum retainer when tightening down on the snap ring |
07-20-2017, 11:55 AM | #6 |
Old member
Googled it.
http://www.quad4x4.com/catalog/categ...ss_NP205_Parts Need Parts for your rugged old New Process NP205 Transfer Case? We have the most complete inventory of new, genuine, USA Made New Process Gear NP205 4x4 transfer case parts in the world. Genuine New Process gears and shafts feature outstanding fit, finish, and durability so critical to high performance NP205 applications and are unequaled for performance under the most rigorous operating conditions. For your less demanding NP205 Transfer Case installations, check out our selection of good quality, low cost, aftermarket replacement parts. Our aftermarket parts will give great service for many NP205 applications, but if you are running a Cummins Diesel or really souped-up gas engine in front of your 205, we strongly recommend you stick with our Torque KingŪ genuine New Process gears, shafts, and parts for maximum performance and life. NP205 History: Chrysler's New Process Gear of Syracuse, New York manufactured the rugged and reliable NP205 gear drive transfer case for 1969 to 1993 model year... (Continued at Bottom of Page) Try here as well. http://www.americanpowertrainwarehouse.com/np205/
