07-23-2017, 02:25 PM | #1 |
Big Block Bellhousing Crossmember for manual transmission
Does one exist specifically for big blocks?
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
07-23-2017, 02:33 PM | #2 |
Re: Big Block Bellhousing Crossmember for manual transmission
I think the bellhousing for a big block could be machined differently, anyone have a known big block bellhousing for pictures?
07-23-2017, 10:50 PM | #3 |
I swapped out the 350 for a 454 and it bolted up perfect. Don't know if original bbc trucks are different but SBC works without any issues. I even used same bell housing for my m21 swap. If u needing one I have an extra that I don't need.
07-23-2017, 11:34 PM | #4 | |
The Older Generation
Thanks. LockDoc
07-24-2017, 07:54 AM | #5 |
Yes. The big block manual trans crossmember exists, and it is different. Not near as many big block manual trucks as small blocks so they can be hard to find. Not sure what all the additional parts you need are, but clutch pushrod from pedal to z bar, z bar, fram bracket etc. are all different if I remember correctly. High hump floor has different location for shifter hole as well.
I looked for a long time to find all these parts when I was going to convert my 70 Sierra Grande to manual.
07-24-2017, 10:08 AM | #6 | |
