![]() Join Date: Oct 2016
What is this silver box by the fusebox?
Hello again!
Working on my daughters 67 C10 some more. Been having some electrical issues, but think I have it narrowed down to the battery (Which was new! lol) I do have a question... When I first hook the battery up, this silver box clicks. Each time I pull the neg cable off, then put it back on, it clicks. What is it, and should it click everytime I hook up the battery? It is to the right of the fusebox on the firewall. Thanks! |
![]() Join Date: Oct 2010
Re: What is this silver box by the fusebox?
That is the relay for the horn.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Is it supposed to click when I hook up the battery? The horn button in the steering column isn't hooked up, it has a smaller aftermarket steering wheel on it with no horn, I assume the wire is just "In there" somewhere in the column....
The wire may be grounding inside the column. If you are not using the horn you can unhook the relay.
From the look of the wiring someone may have installed a remote horn button. I had horn issues ended up the turn signal lever retaining screw in the steering wheel had come loose so I had to pull the wheel to tighten I live in a big city definitely need my horn.
The previous owner had did some "Creative" wiring.. lol.. So I assume the clicking means the wire in the column must be grounding? I want to hook up a horn in the future with a different steering wheel, but for now won't be using a horn. So I can just unplug it without it affecting anything else till I can get to hooking up a horn button?
#7 | |
The Older Generation
LockDoc
Is this a NO or NC relay ,, could account for clicking when energized
Stan 67 swb BLU MULE posted via flip-fone |
![]() Join Date: Jul 2015
Should be normally open
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
And then wrapped it in roofing tar!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
