Old 07-26-2017, 08:58 AM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
87 Fuel Sender Conversion
Since photosuckit has made a change that does not allow 3rd party hosting without paying $400 a year, I decided to redo this how to on what I did to a stock 1987 sender to use with a LS swap. This sender is for the Driver Side Tank,
Pictured are the parts for the conversion of a 1987 GM Truck fuel sender for use with an LSx engine.
Sender: Spectra Premium, Driver side tank: #FG05M (pictured) -OR- Passenger side tank: #FG05N
Fuel Pump: Bosch #69225 (same as an ACDelco EP381)
Kit includes clamps, fuel line, isolator, wiring pigtail and clamps for install.
Strainer: Spectra Premium #STR01 (required for Fuel Pump Warranty)
Fittings:
Jegs 3/8” tube to -6 Male AN Fitting (#100551) Feed Line
Earl’s 3/8” tube to -6 Male AN Fitting (#165006) Feed Line
Earl’s 5/16” tube to -6 Male AN Fitting (#165056) Return Line
(I used one Earl’s and one Jegs because of cost, I saved a few bucks & Jegs did not have the 5/16” fitting)
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-26-2017, 09:04 AM   #2
aggie91
aggie91's Avatar
Re: 87 Fuel Sender Conversion
First step is to cut off the bulge on the ends of the supply and return lines coming out the top of the center. First picture, the left line is the 5/16” diameter return line, center line is the 1/4” diameter vent tube, and the right line is the 3/8” diameter supply line.
Second picture is after I cut off the bulge on the ends. Once the ends are cut off, de-bur the ends and the ID of each line and flush the lines with brake cleaner to remove all the metal shavings.
Karl
The LST Challenge:
Old 07-26-2017, 09:05 AM   #3
aggie91
aggie91's Avatar
Next, install the adapter fittings on the corresponding line. Shown here is the 3/8” Feed Line fitting. Tighten as per the manufacturer’s directions.
Karl
The LST Challenge:
Old 07-26-2017, 09:07 AM   #4
aggie91
aggie91's Avatar
Repeat above step for the 5/16” Return Line. For this line I had to move the support tab for the line on the sender out of the way and bend back into place once the fitting was installed. I also had to resize the line using a pair of regular pliers, being careful to keep the line round.
Karl
The LST Challenge:
Old 07-26-2017, 09:09 AM   #5
aggie91
aggie91's Avatar
Next install the Fuel Pump to the supply line on the sender and install the strainer to the bottom of the pump. The clamps shown on the black like are the special fuel injection clamps that hold better then standard hose clamps.
Karl
The LST Challenge:
Old 07-26-2017, 09:15 AM   #6
aggie91
aggie91's Avatar
You now should have a complete ready to install sender to work with your LS Swapped Square Body!
I used push lock hose and fittings with -6 ends to connect the sender up to the rails on the engine. Quick and effective. For the metal lines on the fuel rail on the intake, I used the same Earl's fitting without cutting off any of the factory line. Sorry, I don't have a picture of that set up...
My son has also done this same conversion using a Walbro 400/450 pump. the only thing he had to do different is the bracket on the bottom of the hanger needs to be cut off and a hose clamp used to hold the pump to the tube next to the pump. That set up supported his 550RWHP on his turbo'd 5.3
Karl
The LST Challenge:
Last edited by aggie91; 07-26-2017 at 09:15 AM. Reason: added picture of complete unit...
Old 07-27-2017, 08:42 PM   #7
dec010974
dec010974's Avatar
Hey aggie91. We must be related
dec010974 is offline   Reply With Quote
Old 07-27-2017, 11:08 PM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
It's not necessary to have an -AN fitting on the fuel sender. Don't want to confuse other people out there... I've ran 8 years on a regular hose clamp on FI hose to the stock 87 filter.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-28-2017, 08:19 AM   #9
dec010974
dec010974's Avatar
I'm glad you cleared that up 87chevy.com. I have used FI clamps before on temporary basis. I personally prefer braided lines. I use braided lines for power steering hose, fuel line hose, transmission line hose, catch can hose, and steam line hose. I wish you all the best for your swaps. Clark.
Old 07-29-2017, 12:03 AM   #10
87chevy.com
Power steering is different.. 750psi vs fuel 70psi. it requires special hose and matching fittings. I have used aeroquip blur nylon power steering hose and fittings without a problem. I wouldn't recommend a hose clamp on a pressure line unless I was stranded.
Clint
Old 07-31-2017, 09:05 AM   #11
aggie91
aggie91's Avatar
Clint
I never said it HAD to use the AN fittings on the sender. Not trying to confuse anyone here. This is how I did it and it was really easy to accomplish. I prefer them over the fuel injection clamps for piece of mind. I have had them leak and fail in other applications in the 60-70 psi range.
To Clint's point, it is not necessary for the AN fittings if you want to use the fuel injection rubber hose and the clamps, they will work.
Karl
The LST Challenge:
Old 08-04-2017, 12:09 PM   #12
solidaxel
solidaxel's Avatar
I did the same thing with steel AN fittings, I just ran a drill through the center to make the ID same as the sender pipe and then silver soldered them together and then used tefelon lined steel braded hoses
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
1987, ls swap, sender
