08-01-2017, 10:13 PM | #1 |
What's missing on this seat track?
I pulled the seat today to install the center seat belt mounting brackets. Looking at my seat tracks is something missing, should they be connected someway. It has never worked right and I'm trying to figure out what I'm missing.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 08-01-2017 at 10:18 PM. |
08-01-2017, 10:47 PM | #2 |
Re: What's missing on this seat track?
There's a cable that crosses over so that both sides release at the same time. Your tracks are missing that.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-01-2017, 11:46 PM | #3 |
The Older Generation
Some are cable, some are a rod, and some are a thin wire. I don't remember the specifics but it depends on the year. Here are a few threads on the subject. http://67-72chevytrucks.com/vboard/s...d.php?t=420114 http://67-72chevytrucks.com/vboard/s...d.php?t=659974 http://67-72chevytrucks.com/vboard/s...d.php?t=418802 LockDoc
08-02-2017, 01:05 AM | #4 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-02-2017, 06:32 AM | #5 |
As others have said, some seats have cable, some have a rod. See arrow on attached pic.
Mine had a cable which was kind of thin, so I replaced with a rod. I bought a 6 foot 1/8" diameter steel rod at Lowes. Painted it gloss black. The rod attaches to the two spring loaded catches on the seat tracks. Just cut to fit and bend the ends to hold in the holes for the catches. The tension on the rod, or cable, is adjusted by being attached to the bottom back of the seat frame. I use a large wire tie to do this. You install the seat with the wire tie just tight enough to keep the rod above the hump of the cab then tighten it until the passenger side track works in conjunction with the drivers side track. Doing it this way keeps you from having to install and remove the seat numerous times to get the adjustment right. You are also missing the spring on the drivers side which keeps tension on the whole seat. See circle on attached pic. There is also a smaller spring that keeps tension on the handle. You can see it in the second pic. Hope this helps. |
08-02-2017, 10:14 AM | #6 |
The seat is missing
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
08-02-2017, 10:47 AM | #7 | |
there's always one in the crowd..
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 08-02-2017 at 04:37 PM. |
08-02-2017, 11:57 AM | #8 | |
• Bench to bracket spring: A 11.3/4" spring attaches to the bottom rear bench frame. The hole is located approx. 4.1/2" from the bracket. It slips into the hole over the bench cover. The other end attaches to the hole located on the inside of the bracket near the front. • Seat adjuster spring: The short end of a 7.1/4" spring slips through top of the hole in the adjuster handle. The other end attaches to the bottom rear corner where the track and bracket meet. Once attached, bend the end of the spring in at the handle.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-02-2017 at 12:05 PM. |
08-02-2017, 04:36 PM | #9 | |
I may not ever move the seat but the ocd in me wants things done right, I hate half ass stuff and the PO left plenty of that for me....... and it also gives me a chance to paint the seat track in the mean time. I only wish I was ready to redo the seat now that it's out. i''l mention it here... WTB this rod in the pic
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-02-2017, 06:29 PM | #10 |
hdff.....I did the restore on the seat myself.
It did take a lot of effort, but I am really happy with the results. I will PM you my cell number to discuss. |
08-04-2017, 09:03 PM | #11 |
Ok I got it I'll give you a call soon...
