Old 08-15-2017, 05:57 AM   #1
ShortCST
ShortCST's Avatar
1968 Factory Delco AM Radio Troubleshooting Guide?
I searched "Radio" and got 160 search results from the forums. Didn't find a troubleshooting guide. I ordered a new 8 ohm speaker from S&M Electro-Tech, and installed it.
No light on the radio, and zero sound. The sound went out a couple of years ago. Then the light.
I have a good digital multimeter, and I'm good at troubleshooting.
Is there a good troubleshooting guide available somewhere online for these radios?
Thanks in advance.
ShortCST is offline   Reply With Quote
Old 08-15-2017, 11:24 AM   #2
bill3rail
bill3rail's Avatar
Re: 1968 Factory Delco AM Radio Troubleshooting Guide?
I have three AM radios and would like some information on them also.
The one in my truck worked for a few minutes then stopped. It was drawing a lot of amperage as the wire was getting too hot. I removed power from it and have not touched it since.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-15-2017, 11:56 AM   #3
demian5
demian5's Avatar
Pop the top and start fixing it!
I fixed my 64 impala by finding a bad solder joint and replaced the bulb.
My sons factory am/fm on his 86 re-soldered all of the speaker connection solder joints in the radio and the speaker started working. You could get them to come on/off by wiggling the connector at the back of the radio.
Simple machines.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-15-2017, 12:32 PM   #4
FirstOwner69
FirstOwner69's Avatar
I have 2 AM radios. One is model #11TB1. The other is 91TB1. Based on the numbers on the covers of these manuals and the fact that one is from my 69, my bet is that the first digit is the last digit of the truck year. They both also have Product No. 7305841 on the labels.
Based on that, I did an Internet search and found this:
https://www.samswebsite.com/en/photo...earch&s=Search
And, on eBay:
http://www.ebay.com/itm/Sams-Photofa...EAAOSw6GBZcztK
http://www.ebay.com/itm/Sams-Photofa...CWu3D8ZURhbYhg
http://www.ebay.com/itm/Sams-Photofa...sAAOxy63FS~RyK
FirstOwner69 is offline   Reply With Quote
Old 08-15-2017, 05:16 PM   #5
ShortCST
ShortCST's Avatar
Thanks guys! Are there any things that I can check with my multimeter and a flashlight before I yank the radio out of the dash?
Old 08-15-2017, 05:45 PM   #6
hamjet
hamjet's Avatar
yes, remove the plug from the back of the radio and make sure you have 12 volts to start...make sure the key is on....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 08-15-2017, 05:46 PM   #7
ShortCST
ShortCST's Avatar
Thanks Joe. Will I only find 12 volts at one terminal on that plug?
Old 08-15-2017, 05:50 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Seems like I read somewhere that turning on the radio with no speaker attached could damage the radio. Don't know if that would include a non-working speaker too or not....
LockDoc
Leon
Old 08-15-2017, 05:53 PM   #9
ShortCST
ShortCST's Avatar
LockDoc
Damn, that would suck.
Old 08-15-2017, 06:11 PM   #10
LockDoc
LockDoc's Avatar
Here is a quote from a members post....
The first thing I'd do would be to get a known good 8 ohm speaker and connect to the radio. You could burn up the output transistor trying to play the radio with an open speaker, or none at all.
LockDoc
Leon
Old 08-15-2017, 06:52 PM   #11
ShortCST
ShortCST's Avatar
LockDoc
Praying that guy didn't know what he was talking about.
Old 08-18-2017, 05:04 AM   #12
ShortCST
ShortCST's Avatar
And, on eBay:
I'm sorry to be such a pain and keep asking about this. I just yanked my radio, and it has the same model number. 7305841.
That first link that you sent (thank you) has 7 search results for that model number. Do you know if there's a difference? Obviously, I'm looking for a troubleshooting/diagnosis/repair manual/guide. Maybe these are just schematics, and the troubleshooting is up to Google and me?
Thanks again for the links. I really appreciate it.
Old 08-18-2017, 10:12 AM   #13
FirstOwner69
I remembered that website from a previous thread and don't have any personal experience. You could email Sam's and ask them which applies to your radio.
Unless you really have an attachment to that radio, it would probably be a lot easier to replace it. It appears that the AM radios generally sell for under $75 based on the sales on the parts board. The junkyard near me sells them for $15-$20 when they have them.
