10-30-2017, 02:19 PM | #1 |
1950 3100 door glass help
I really need some help with my door glass. I have full door glass with frames and have purchased the run channel but it is to thick so the inside door frame will not fit ? Any help and pics would be great thanks
10-31-2017, 09:07 AM | #2 |
Re: 1950 3100 door glass help
Pics of your problem would help us too
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
11-09-2017, 12:55 PM | #3 |
Definitely need a better description of what the problem is. I can't really figure it out based on the OP. Take more than 30 seconds to construct the question and repost. And yea, some pics too, if you want.
12-01-2017, 10:24 PM | #4 |
1 post probably won't check back....
But channels are two different sizes. If I remember correctly Mon wing doors are thicker. Both you shape and trimbto fit |
12-01-2017, 11:03 PM | #5 |
if you have a corrugated looking channel in the door currently, thats the remnants of the old felts. threw me off too fist time i did it, had to remove the channel to install the new felts.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-02-2017, 01:26 AM | #6 |
Tags |
1947, 1948 |
