Old 12-15-2017, 09:56 PM   #1
69BUCKET
Lowering block shims
I bought a set of blocks from POL...and did some other reading on angle needing to be corrected with shims. What are people using? I did see CCC sells a set of blocks with correction to angle problem....any advice?
69BUCKET is offline   Reply With Quote
Old 12-16-2017, 09:26 AM   #2
notsolo
notsolo's Avatar
Re: Lowering block shims
I had some 2" aluminum drop blocks, figured the angle I needed and cut them length wise. Mine were about 2"- down to 3/4". Get the truck set at ride height and use angle finder to get angle at the trans, then match the pinion angle to it.
notsolo is offline   Reply With Quote
Old 12-16-2017, 11:03 AM   #3
69BUCKET
Is this what everyone does for lowering rear end? Measure the trans angle with it installed? How do you get the angle finder in there?
Old 12-17-2017, 04:38 PM   #4
69BUCKET
Western Chassis makes some specific angle shims...anyone using these in combination with lowering blocks?
Old 12-17-2017, 05:14 PM   #5
davischevy
davischevy's Avatar
I just lay the angle finder along the side of the driveline.
Most auto parts stores have pinion angle shims.
You have to measure angle with the suspension loaded IE; sitting on the ground or on a four post lift.
Don't be surprised if you don't nail it on the first try.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
