Wire harness plug at firewall bolt size.
I hate to take your time on such a silly question but can anyone tell me the size of bolt that holds the wire harness to the firewall? Diameter, length, thread pitch.
Thanks |
#2 | |
The Older Generation
Re: Wire harness plug at firewall bolt size.
No problem on the time. This is what we like to do. It's a special bolt. Thread size and pitch is 1/4 - 20 x 1 5/8 long overall, but it has a 3/8 head with a small integral washer built in, and a groove just above the threads for a small snap ring. The head has to be small to be able to get a socket down in the recess to remove it. The snap ring is there to separate the inner and outer parts of the bulkhead connector as you unscrew it. I see no reason a person couldn't use a socket head cap screw to replace it if you can't find one. Salvage yard or here on the parts board would be your best bet for an original. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-20-2017 at 12:32 AM. |
Thank you - thank you LockDoc. That was exactly what I needed to know. I picked up a stainless allen head cap bolt those dimensions and it worked perfectly.
#4 | |
Good deal! Glad you got it buttoned up.... LockDoc
![]() Join Date: Dec 2013
Awesome info LockDoc. When is it that your full set of 67-72 encyclopedias is scheduled for release?
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
#6 | |
![]() Bad part is that I am still learning things about these trucks. It never ends..... Thanks, LockDoc
