drum brakes to disbrake for my 1969 gmc
where the best places to find them ,and how much do they run lmk thanks
Old member
If your talking front brakes then I would try finding a whole 73 up truck and swapping them out for the whole cradle.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: drum brakes to disbrake for my 1969 gmc
What’s your skill set? How much time do you have versus $? For my 69 I went ECE conversion spindles which keep 69 tie rod ends and ball joints. I’d do the same again. I think cost was $800 range?
I did 2” lowering springvas well. DJM flip in rear on my leaf spring truck.
#4 | ||
"I ain't nobody, dork."
Pretty vague question. With the aftermarket for these trucks being wide open and so many good vendors out there. There really isn't a difinitive answer.
Cheapest would be to use stuff from a donor 71-72. But then you're converting to 5 lug. If you want 6 lug, the aftermarket covers that with 6 lug disc rotors. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Moderator
![]() Join Date: May 2007
Hit the easy button and just buy conversion spindles. No need to worry about balljoint and tie rod mixing and matching.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
67-72 parts collector,…
![]() Join Date: Nov 2002
x2
To keep it six lug and be able to buy parts from the auto parts store here is what I recommend:
https://scarebird.com/index.php?rout...product_id=150 And you will need a 71-72 Master cylinder and combination valve to replace the one on your all drum truck. Pretty simeple deal.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
