![]() Join Date: Jul 2010
No Limit Square Body 4-Bar
We have now finished our first production run of Square Body FatBar 4-bar systems. Two years of testing and fitment checks have paid off well. This may be our best FatBar system yet, with the ride height, roll center and anti-squat matched perfectly to the truck.
These kits are as complete as we could make them to help with an easy install. All of the chassis side brackets fit OE holes in the chassis. An aluminum 'C' notch template (no flimsy paper) makes locating the notch cut easy and accurate. All hardware is grade-8. You get: Chassis side 4-Bar mounting brackets, integrated 'C' notch with upper coil-over mounts, notch brace crossmember with panhard bar mount and brake line tab, Axle mounts for coil-overs, 4-bars and panhard mount, FatBars and panhard bar with stainless adjusters, Coil-over shocks and springs and all hardware and instructions. The complete kit is priced at $1590. There are a few things to note. * Ride height is adjustable. Drop from stock height is appx 4" to 7" * This kit fits Short bed and Longbed, but not Blazer. We are working on it. * The four bars and coil-overs are outboard. Total space required is 4" out from the frame. this is about 3/4" more room than the leaf. You can widen the tubb to get 16" of tire clearance. * The front 4-bar mount locates to the front side of the OE leaf mount holes. This is needed to fit the longer bars to get the geometry correct. Due to the bar length, OE "outboard" mounted fuel tanks will NOT fit. * Yes, your forum discount applies.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
Re: No Limit Square Body 4-Bar
Rob, that is a pretty bad ass set up! I damn sure wish shipping to Hawaii wasn't so crazy! The price you pay to live in paradise (and rust).
![]() ![]() Is there a reason the c notch is so shallow? It looks like you could get a lil more out of it and still be safe? Your the expert though - just wondering if there is a reason.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 Last edited by 808_67C10; 01-06-2018 at 10:04 PM. |
So this is a coil over conversion kit? Will the blazer kit fit a burb?
#4 | |
Yes, coil-over & 4-bar, no more leafs. Does not fit Blazer, yet. We have not fit a 'Burb, but this should be the same as LWB. ??
#6 | |
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
