Old 01-08-2018, 12:30 PM   #1
Coursey
Coursey's Avatar
3 point seat belt in rear seat of Blazer??
Has anyone installed 3 point seat belts in the rear seat of a 1976 Blazer?
I want to still use the factory seat and would like the install to look as "factory" as possible.
I have a 6 year old girl that will be riding in the back and want something safer for her.
Any ideas??
Coursey is offline   Reply With Quote
Old 01-08-2018, 02:11 PM   #2
hewittca
hewittca's Avatar
Re: 3 point seat belt in rear seat of Blazer??
In to see what others suggest. I've been throwing around the idea of selling my C10 to get a Blazer since it is more family friendly for my two little ones, but have so far axed the idea for one reason alone: safety, or lack thereof.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-08-2018, 03:50 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Later Blazers had factory 3-point belts in the rear, mounted to the top. Maybe 88-91 tops? I'm not sure of the exact years. Others have used third-row Suburban seats out of 00-06 models. The width is a good match and the seat belts are integral in those but you'll have to fab your own mounts.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-09-2018, 08:26 AM   #4
Zook75
Zook75's Avatar
I just got a 91 Jimmy with the rear 3 point belts mounted to the top. They will be coming out soon to be replaced with lap only belts once I do a little research. I'm pretty sure my deal will be just installing the belt to the stock mounting location on the floor. but I'm not sure how they are mounted in the top.
Zook75 is offline   Reply With Quote
Old 01-09-2018, 08:48 AM   #5
Coursey
Coursey's Avatar
Zook75,
Can you post a pic of how it attaches.
I am not sure about attaching to the top on mine 1976. It seems that there would not be enough structure there to hold in an impact. The later tops must have reinforcement in that area?
Old 01-09-2018, 09:39 AM   #6
Zook75
Zook75's Avatar
Originally Posted by Coursey View Post
Zook75,
I can't get the cover off but the winder is all up there.
Old 01-09-2018, 10:08 AM   #7
Coursey
Coursey's Avatar
Thanks. I assume this would require finding a different top.
Old 01-10-2018, 09:35 AM   #8
Zook75
Zook75's Avatar
I'll know more once I pull that cover off.
Where can I get the wrench to pull the bolts to remove the top?
Old 01-10-2018, 03:55 PM   #9
Irish1941
Irish1941's Avatar
As was said, you'd need the 90-91 top
GM placed mounting bolts right into the top's inner steel structure. It would be pretty hard to do it yourself and be safe.
You would also need the 90-91 center belts as well as GM switched seat belt suppliers and the 78-89 belts won't work with the 90-91 shoulder harness.
Plus think you need to add the outer male seat belt bolt mount to the floor next to wheel well.
73-77 belts bolted to the floor thru the rear leg of the seat if I remember right.
Only real problem after that I can see is the armrest of the seat getting in the way of the shoulder harness.
Might be able to use a 87-89 armrest?
As for the switch to lap belts, unbolt the 3 point floor mount and bolt in the 78-89 male ends and use the matching 78-89 center belts.
The shoulder harness uses same hole beside the seat in the floor as the earlier trucks.
oh and the later top bolts are just torx T35H or T40H.
Any parts store should a set of security torx bits.
Irish1941 is offline   Reply With Quote
Old 01-11-2018, 06:24 PM   #10
Zook75
Zook75's Avatar
Thanks Irish. with all that said I'm in the market for everything needed to add the lap only belts. even if I never take the top off, I hate them things just hanging down on both sides.
Old 01-11-2018, 06:28 PM   #11
phillipm
I used a universal lap belt kit. Bolted it to the floor on the outside with a 90* bracket and to the seat where the original center parts bolted. Done.
Old 01-12-2018, 01:25 AM   #12
68Timber
68Timber's Avatar
I’ll have an extra set of rear belts soon, at least the pieces that mount to the rear seat. If you’re not in a big hurry.
John
74 Honda Z50 build
Old 01-12-2018, 01:47 AM   #13
Huggerorangeblood
I just noticed my right rear 3 point harness is about torn in half. Can we still get the webbing and have upholstery shop sew it in? Or do I need to buy the whole thing? It’s blue.
Huggerorangeblood is offline   Reply With Quote
Old 01-12-2018, 09:20 AM   #14
frenchy51
frenchy51's Avatar
A later top would be the answer or possibly mount a roll bar for added safety and attach the 3 points to it?
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 01-12-2018, 11:56 AM   #15
Irish1941
Irish1941's Avatar
Check out this guys
http://www.ssnake-oyl.com/mm5/mercha...ode=SB_WEBBING
They do seatbelt resto but they do sell just the webbing.
Used ones are going to be tough to find.
Old 01-13-2018, 01:13 AM   #16
Huggerorangeblood
Thanks Irish. Talked to them today and going to ship my assembly out on Monday. My local shop said they can sew webbing but can’t service the retractor part.
Old 01-13-2018, 03:31 PM   #17
Huggerorangeblood
How do you remove the plastic cover from the overhead retractor. I don’t want to break it.
Old 01-13-2018, 09:10 PM   #18
tobiahr
tobiahr's Avatar
I have to second 68Timber with the suggestion of using late model Suburban seats with the integral seatbelts.
An awesome example is tvblazer78's http://67-72chevytrucks.com/vboard/s...3&postcount=47
tobiahr is offline   Reply With Quote
Old 01-14-2018, 11:11 AM   #19
Zook75
Zook75's Avatar
That would be great Timber. Thanks.
Old 01-14-2018, 05:28 PM   #20
68Timber
68Timber's Avatar
No problem, I'll save them. I might be able to get you the anchor pieces that mount to the floor. I'll check.
John
74 Honda Z50 build
Old 01-22-2018, 06:58 PM   #21
Zook75
Zook75's Avatar
Hugger the cover unsnaps from the out side close to the window and hangs to the inside.
Also this is what the top looks like with them gone.
Old 01-23-2018, 01:55 PM   #22
Electricduane
I think this is the correct answer. The 1991 K5s with the seatbelts attached to the fiberglass top are pretty weird. . . what do you do when you take the top off? The seatbelts wouldn't function at all.
If you have a roll cage put in with the seatbelts attached to it, that would be significantly more secure than anything that the factory ever made.
Electricduane is offline   Reply With Quote
Old 01-24-2018, 04:41 PM   #23
chevy3100truck
I'm putting together a 1990 GMC Jimmy for my wife and the 3-points were part of the problem. They had the roof mounted point, but she wanted to be able to take the roof off. Being as it came from the factory with 3-points it is illegal to run 2-point belts.
Best solution I could come up with - mounting mid 2000's Yukon Denali 3rd row seats. They have 3-point belts built in.
I used 3/16" x 8" x width of floor plates under the 2 rows of mounting points -
http://67-72chevytrucks.com/vboard/s...d.php?t=755107
Works like a charm, have 3 seats in the row and has the legal requirement for seat belts.
Suburban 3rd rows might be a bit cheaper, they aren't split like the Denali / Escalade (and maybe Tahoe?) 3rd rows
chevy3100truck is offline   Reply With Quote
Old 01-24-2018, 07:42 PM   #24
Zook75
Zook75's Avatar
Nice build there. After looking threw the owners manual the top in the last 2 years where not meant to come off. I'm going to take my legal chances with lap belts only. that's all they had for the middle passenger.
Also be careful with any wheels spacers you use, My 75 pickup had 5 to 6 lug spacers on it, and a rear wheel broke off hours before i bought it.
Old 01-25-2018, 11:04 AM   #25
Ski-me
Ski-me's Avatar
Yea, I'd be a little cautious. I put in a 14SF with a touch wider axleshafts. put in some steel spacers between the axle and backing plate to get the brakes in alignment. Now my front and rear tires are parallel. I do like it better that way too!
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
