01-08-2018, 10:37 PM | #1 |
1968 Camaro steering wheel install
This is up there with one of the most enjoyable changes I've ever made, certainly so for the ease of install: the 1968 Camaro walnut steering wheel.
If you're steering wheel shopping here are a couple of notes that may be of use: this wheel is almost 1.5" smaller in diameter than the stock wheel; it's actually a deeper dish than stock '72 truck wheel, but with the smaller diameter means it offers roughly the same driving position; the rim itself is thin, just like the original truck wheel; the walnut is faux, just like the original Camaro. Best of all, the 1968 Camaro wheel is truly a bolt-in change. This wheel is from OER. |
01-08-2018, 11:56 PM | #2 |
Re: 1968 Camaro steering wheel install
That looks great. That's a popular steering wheel swap, although most did the comfort grip. Now that they are reproduced it's practical to use the rosewood wheel.
01-09-2018, 12:44 AM | #3 |
How did I get this OLD!
I did a blue Chevelle comfort grip swap last spring. Love the look,love the feel. Easy swap.
http://67-72chevytrucks.com/vboard/a...1&d=1515472922
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
01-09-2018, 10:00 AM | #4 |
BlahBlahBlah
Both wheels look great. Seems like the dish puts it a little closer to the ol gut though, and "some" of us need all the room we can get =)
01-09-2018, 11:11 AM | #5 | |
When I measured the dish of the Camaro wheel on the workbench I was immediately like, "uh oh!" But there's more to positioning than dish alone and the decrease in diameter over the stock truck wheel helps in this regard. I find it to be a bit roomier than the stock wheel because the bottom of the wheel isn't as low, and yet with the dish it is still as comfortable to steer with my thumb and index finger at the 9 o'clock position and elbow on the window sill. (If that makes any sense?) |
01-09-2018, 02:20 PM | #6 |
Mine is from a 60s Vette but same principle, however, being a GMC, I opted for a Corvette center cap. Nice upgrade!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-09-2018, 08:09 PM | #7 |
Those wheels will always look go on just about any classic from the era.
I used a standard oe 67 camaro wheel on my 71 k20 and got a 67-68 truck horn button too work with it. Here's a terrible pic
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-09-2018, 08:39 PM | #8 |
I swear office, I had no clue how fast I was going
01-09-2018, 09:22 PM | #9 |
Will the 68 camaro hub work for our trucks? I have just a comfort grip wheel I bought used.
Yeah' well sometimes nothin' can be a real cool hand Lucas Jackson |
01-09-2018, 09:31 PM | #10 |
Yes, the 67-68 hub perfect. Not the 69 which is for a column with ignition lock and the adapter is larger diameter.
01-09-2018, 09:32 PM | #11 | |
67-72 parts collector,…
The 67-68 Camaro hub matches the diameter of the truck steering column. The 69 Camaro hub is a larger diameter.
01-09-2018, 10:00 PM | #12 |
Old member
From what I remember the standard Camaro and Corvair wheels the hubs are made to them you don't take them a part. Pictured is a Corvair standard wheel which basically is a Camaro wheel.
The 67 Chevelle wheel is alo 1 piece. This one is in my 71.
01-10-2018, 10:38 AM | #13 | |
https://www.classicindustries.com/pr...ts/*r6532.html |
01-10-2018, 11:19 AM | #14 |
Location: Formerly MD and San Diego, now loving life in Arizona
My truck came with that wheel when I bought it 7 years ago. Now that I am starting to drive it, I had to swap out the wheel with one that didn't have the 4 1/2" setback. I am one of those who needs a bit more room due to being 6'4".
I now have one of those wheels sitting around that I can't use.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
01-10-2018, 12:34 PM | #15 | |
01-10-2018, 12:40 PM | #16 | ||
Old member
This was the reason for my post. The three prong wheel is a opitional steering wheel for a Camaro but it's not the standard wheel that came in them. Yes I agree the one the OP shows does come a part. The hubs are basically the same but some small minor differences are noted on other forums. Horn springs locations and turn signal cam differences also.[ Depending on the site you order from to is a guess as to if it will work are not. I have several hubs that work on my SS Impala that will also work on my trucks. But I have to change out the horn stuff. The wheels pictured has a Corvette hub which is correct except it's a tad bigger diameter than the column.
12-07-2018, 08:52 PM | #17 |
Hi bMR, did the OER steering wheel work with your stock horn assembly? I am having difficulty fitting the stock horn assembly in my 68 c10 onto the OER steering wheel's horn button. Any suggestions?
Tony J |
12-07-2018, 09:29 PM | #18 |
I put a oem comfort grip with a gmc horn button
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
12-07-2018, 10:03 PM | #19 |
I installed a camaro wheel with a corvette horn button to keep my 327 L79 copo theme.
http://67-72chevytrucks.com/vboard/a...1&d=1544234374
12-07-2018, 10:15 PM | #20 | |
12-08-2018, 10:51 AM | #21 |
I put the comfort grip on the 72
12-08-2018, 11:37 AM | #22 |
The Comfortgrip wheel has less dish than the faux wood wheels I think. I have the Comfortgrip wheel in my 69 Camaro, my 69 short step, and in my 79 CJ-5. I think they look great, feel great, and work so much better than the crappy aftermarket horn setups.
12-08-2018, 12:45 PM | #23 | |
A year in I still love this modification. |
12-08-2018, 03:54 PM | #24 |
Thanks for the reply bMR much appreciated.
Tony J |
07-02-2020, 10:57 AM | #25 |
SWB 4x4 Collector
bMr, I just bought the R6532 steering wheel kit from OER. Is that the same wheel you used? How is the wheel holding up? Do you have anymore pics of the the wheel in the sunlight? Thanks Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
