Old 01-18-2018, 10:23 AM   #1
James903
Type of air bags
What type and or brand of air bags are most people running? I’ve used ride tech and some ebay specials and they seem to get the job done. The reason I’m asking is I’m considering try out the Firestone double convoluted bags. I read a article in a magazine awhile back talking about the different types of bags. They mentioned how that style bag handles better then a regular bag. So I’m thinking about trying them out. They cost a little bit more but if they handle better and are a higher quality it’s justifiable. Thanks
James903 is offline   Reply With Quote
Old 01-18-2018, 12:19 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Type of air bags
Ride Tech uses Firestone. I run them 2500 rear and 2600 front. Also run them on my Dodge Diesel 1 ton to level load when towing 5th wheel
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-18-2018, 01:50 PM   #3
tinydb84
tinydb84's Avatar
The type of airbag you run will depend on your suspension set up. Usually you would run a convoluted style on a bag on bar set up and a sleeve type bag on a over axle type set up.
David
Instagram: myfabguy
Old 01-18-2018, 10:20 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
I'm running double convoluted Firestone's all the way around on my '61 Bel Air with Bilstein shocks. It rides & handles pretty well.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
