Old 03-04-2018, 06:00 AM   #1
WOLFMANmike
WOLFMANmike's Avatar
60-66 rear wheel tubs??
Do they make wider rear wheel tubs for our trucks or is something that has to be cut and widened ? Cause i see them being made for the darn 67-72 trucks they call them the +4 wheel tubs metal or fiber glass
WOLFMANmike is offline   Reply With Quote
Old 03-04-2018, 11:32 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 60-66 rear wheel tubs??
Not that I'm aware of just yet. I cut and spliced mine using a damaged pair I found at a salvage yard.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-05-2018, 03:01 AM   #3
kerber63
kerber63's Avatar
I did the same.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 03-05-2018, 11:16 PM   #4
Ehud
Looks good. How much did you widen the tubs?
Ehud is offline   Reply With Quote
Old 03-07-2018, 08:54 PM   #5
kerber63
kerber63's Avatar
I think I went 2-3 inches wider on mine.
1963 C10 short-wide
1963 C10 suburban
Old 03-08-2018, 12:27 AM   #6
rvrfoot
You will need to do your own. Or have some one do it for you.
rvrfoot is offline   Reply With Quote
Old 03-08-2018, 09:34 PM   #7
racecougar
racecougar's Avatar
Same process here. These are 5-3/4" wider than stock.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-09-2018, 10:43 AM   #8
Mack B
Mack B's Avatar
I bet these would be pretty easy to adapt
https://www.brotherstrucks.com/55-72...tinfo/IWT72WD/
Mack B is offline   Reply With Quote
Old 03-09-2018, 03:13 PM   #9
WOLFMANmike
hey now that might work ! i wonder just what mods would need to be done to make them work since they do say 55 - 72 ?
Old 03-09-2018, 07:21 PM   #10
rvrfoot
That is a pretty widespread of years for a universal inter fender?
Old 03-09-2018, 08:34 PM   #11
WOLFMANmike
I know it thats why i wonder what mods would need to be done for our trucks
Old 03-09-2018, 09:39 PM   #12
ImpalaJim
ImpalaJim's Avatar
pretty much the same box all those years
ImpalaJim is offline   Reply With Quote
Old 03-11-2018, 04:39 PM   #13
Lalo831
how bout something custom like this from self made fab.
http://www.selfmadefab.com/product/c...ear-wheel-tubs
Lalo831 is offline   Reply With Quote
Old 03-11-2018, 08:16 PM   #14
rvrfoot
I think it will be easy to make them too buy them?
Old 03-12-2018, 06:40 PM   #15
zachiatrist
zachiatrist's Avatar
You can put the 67-72 4" widened tubs in the rears of our 60-66's. I just put some in mine, they fit just fine. Gotta drill some new holes, no big deal though. Beats cutting and welding new ones all up. Unless you're into doing that, more power to ya!
1964 Chevy C10 "Honeydew"
http://instagram.com/zachiatrist
http://zachiatrist.com
zachiatrist is offline   Reply With Quote
Old 03-12-2018, 11:39 PM   #16
UKNOWME
UKNOWME's Avatar
Sloshtubz makes them
http://www.sloshtubz.net/shop.html#!...egory=18977113
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
