![]() Join Date: Feb 2004
Drop down panhard bar mount
Hey all, does anyone know where to buy a drop down panhard bar mount ? I just installed a 9” and the straight bar wont work. I know I could run a bent bar but it seems a drop down would be about the same price and probably better geometry for a bagged truck.
Thanks for the help!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
![]() Join Date: Sep 2015
Re: Drop down panhard bar mount
How much drop do you need? Rob at No Limit could probably make you one if they don't have one in stock. I didn't use a drop on mine but my mount on the housing is spaced away from the housing so that it clears.
http://67-72chevytrucks.com/vboard/s...d.php?t=709504 |
I ended up ordering the cpp bent bar, but I still think it would be a better set up with about a 4" drop on the frame Mount.
My 68 c10 got a ford 9" and i installed a porterbuilt pan hard bar kit including a new frame mount. I'm running 4" drop ece springs with 1" lowering blocks, 18" wheels and the bar sits horizontal and parallel to the rear end.
