Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 04-16-2018, 01:17 PM   #1
OldChevy1954
Comet mixture for cleaning old paint?
Anybody heard of a 'Comet cleanser mixture' for cleaning and brightening old paint? If yes, what is the mixture, ratio and how do you apply it?
I'm going to try and brighten up my paint and want to try this if it works.
Thanks for the info if anybody has done this.
OldChevy
OldChevy1954 is offline   Reply With Quote
Old 04-16-2018, 02:19 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Comet mixture for cleaning old paint?
OldChevy
I thought Comet had Pumice in it. If it does it would scratch the paint. Why not use Turtle Wax White Polishing Compound then put a coat of wax on it? Here is a before and after picture of my '70 hood using that combination, and an overall picture of the whole truck. It takes a little work but it is well worth it.....
LockDoc
Leon
Old 04-16-2018, 03:15 PM   #3
OldChevy1954
Hey LockDoc, what's that paint color and code for your truck? I like that color for my old bed I'm going to refinish.
Maybe it isn't Comet ... but I believe it was a household powdered cleanser that was used to refresh the paint?
Thanks.
Old 04-16-2018, 03:48 PM   #4
Joesjunk
Joesjunk's Avatar
Comet and water will shine up old paint. I have just put comet in a wet sponge and scrubed away
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 04-16-2018, 04:33 PM   #5
weim55
This is the difference using just a Comet wash with no compound or wax after. This truck sat outside unwashed for 35 years. The comet wash was perfect for the appearance " I " desire.......,
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 04-16-2018, 04:40 PM   #6
weim55
The Comet ( Ajax in my case ) does a great job of removing the oxidation. I'm sure I could cut and buff it from here and this paint would shine pretty good.
Old 04-16-2018, 05:12 PM   #7
weim55
As for a ratio, no rocket science here, pull the scrub brush out of the wash bucket wet,dump the Comet onto the brush straight out of the can, and scrub away. Good idea to test a section in and inconspicuous place to test the effectiveness first.
Old 04-16-2018, 09:05 PM   #8
Comet has fine abrasive which is why it works, same as rubbing and polishing compounds. You need that to cut the paint and that's why you see the paint on you applicator. I use liquid clay bar because it cuts into the paint to a minimum. Very low risk for cutting too deep. I do it by hand
Old 04-16-2018, 09:16 PM   #9
1968aj
my old paint had white chalky like spots all over. I wiped some boiled linseed oil on it and the white stuff disappeared and the paint shined up good.i have used polishing compound ; wax; clr ; and everything else I have but the linseed oil gave me the best and easiest results.
1968aj is offline   Reply With Quote
Old 04-17-2018, 12:17 AM   #10
LockDoc
LockDoc's Avatar
Thanks.
Posted by member "SS Tim":
Both actually.
514 is the GM paint code for solid red or "Light Red" on your '70 truck.
544 is the paint code for 514 Light Red and 521 White in the Conventional Two-Tone scheme (white roof and red primary).
593 is the paint code for 514 Light Red and 521 White in the Special Two-Tone scheme (white roof, red primary and white rockers).
LockDoc
Leon
