Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-16-2018, 11:19 PM   #1
longbed67
longbed67's Avatar
2 Post Lift
I'm looking to add a two post lift to my shop. I will mostly be using it to work on my 67 c10 but will occasionally use it to lift my duramax which weighs in at 8800 lbs on the grain scale in town. My concrete is 6-8" thick with steel and fiber as ive been told some lifts require 6" minimum. What two post lifts do you like and why? Which ones don't you like and why. Thank you in advance.
Admins please move or delete this if I am in the wrong area.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-17-2018, 12:09 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 2 Post Lift
I have a atlas OH-10x lift....extra wide extra tall...I love it ...had many a crew cab diesel 4x4s on it ...never failed to lift anything ive put on it...got it from greg smith....they have free shipping..right to your door if you have a way to unload it....this is the one I have..theyve gone up since I got mine...think I gave 2195 for mine 6 yrs ago......http://www.gregsmithequipment.com/At...IDE-EXTRA-TALL
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-17-2018, 09:21 AM   #3
Advanced Design
Advanced Design's Avatar
Re: 2 Post Lift
I put in a 10,000 lb Rotary lift as it is the lift many dealerships use. http://www.rotarylift.com
Advanced Design is offline   Reply With Quote
Old 04-17-2018, 09:28 AM   #4
duke_lbz
duke_lbz's Avatar
Re: 2 Post Lift
I do a lot of work on diesel trucks in my home shop and have a rotary. Have had it about 2 years with no complaints but the are pricey. We have a challenger lift at work and I would say its just as good for about half the price.
07 GMC Sierra 2500 compound turbo' duramax
99 GMC Yukon solid axle swapped
67 Chevy c10 small window swb stepside supercharged ls6
70 Chevy c10 suburban
72 K5 Blazer 4wd
duke_lbz is offline   Reply With Quote
Old 04-17-2018, 10:46 AM   #5
B. W.
B. W.'s Avatar
Re: 2 Post Lift
X3 on Rotary, have used them for over 20 years, have lifted many diesels, many times.
B. W. is offline   Reply With Quote
Old 04-17-2018, 12:17 PM   #6
Bigdav160
Bigdav160's Avatar
Re: 2 Post Lift
If price is no object, then I think Mohawk makes one the best lifts. Asian (non certified) lifts usually undersize the pump so you never risk lifting too much. i.e a 9000lb lift might only have a pump capable of lifting 8000lb.
I have an older Rotary spo-88 in my garage. I would never think of trying to lift my diesel truck with it. I am not sure I would lift my 4x4 Suburban with it but it does fine with the Corvettes and Z-28
We have Rotary spo9's at the shop. They do lift my diesel trucks but you can tell there is that much weight. It seems to scare some people.
I would definitely look for a 10k or higher rating.
edit: I think most 2-post lifts are fine with 4" concrete but check the specifications.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-18-2018, 08:51 AM   #7
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 2 Post Lift
I only have experience with the Mohawk. So far, so good.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-19-2018, 01:40 PM   #8
nlped
nlped's Avatar
Re: 2 Post Lift
I have a Rotary & I have lifted a couple of diesel 4x4’s without issue.
Not a diesel, but a gratuitous shot of my working lift...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-19-2018, 07:38 PM   #9
BCOWANWHEELS
Re: 2 Post Lift
if it aint a rotary its like buying harbor freight tools
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 04-22-2018, 03:35 PM   #10
truckdude239
truckdude239's Avatar
Re: 2 Post Lift
I run forward lifts in my shop but they are like 20 years old and i am told they dont make them like that anymore
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
