bucket don't line up in cradle
Bucket on drivers side sits to the outside of middle about 1/2 in. It appears that the adjusters holes are off to the right. Do I extend these slots, or what are my options? '68 stepside
Re: bucket don't line up in cradle
If you are saying you have original c10 bucket seats ,this would be correct the c 10 bucket seats have a different hole pattern then a c10 bech seat. If you look close enough there might be indentions for the bucket seat bracket location, I have seen this on one cab that I aquired for parts. there is also the underside brace , but i dont remember if they have one specific for buckets , maybe someone else might chime in on that I am not that familar on the subject about the bracing.
No, actually I'm talking about the headlight bucket. The bucket doesn't sit in the radiator cradle right. This causes the light to sit too far to the right
#4 | |
Post Whore
![]() Join Date: Feb 2016
I too jumped on the seat bandwagon.
![]() Definitely need some pictures on this one. And is there any aftermarket sheet metal involved?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Right side bucket on left side ?
Bucket upside down ? Gmc bucket on a chevy vise versa |
The Older Generation
I am an advocate of bringing up older threads but I am betting the OP has this problem solved by now..... ![]() LockDoc
#8 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Thanks doc i did not notice the old date either
Post Whore
Man! That Leon is still the quickest pony on the track!
I'm not sure what even made me look at the date. I usually just jump on the band wagon too. ![]() LockDoc
#13 |
I would still like to know the outcome...lol
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#14 |
Well, since we are talking headlight buckets, I don't think the bucket alignment is affected if you swap sides or try to use a left on the right or vise versa. The only issue that causes is the headlight won't be rotated correctly in the bucket. My truck somehow had two RH buckets. I simply make new headlight notices in on of the buckets to make it a LH bucket.
But, the bucket alignment left to right within the grille was never a problem. The PO simply retained the headlight in place with the alignment tabs outside the slots in the bucket. |
