05-12-2018, 11:34 PM | #1 |
Overheating, tried (almost) everything.
This is a barn find I picked up a couple years ago, I have done the usual stuff that you do to a truck that sat for 15 years. New brakes all round, axle seals, new carb, plugs, wires, etc.
The truck is a hodge podge of what I imagine were spare parts. Its a 1981 with a pre-1976 stepside box, and a 1983-1984 front end. It seems like the interior is built the same way. When I got it it had a 1975 gauge package (or so), and nothing worked. I bought some NVU gauges, and thats when I found out I definitely had a cooling problem. The truck idles nice, and I can drive 40 mph all day long and itll stay at 180. When I take it on the highway though it climbs and climbs, it hit 250 today and I had to pull over. So far I have: - flushed the cooling system 3 times - replaced the thermostat with a 165F - replaced the rad cap - moved the temp sensor from the head to the intake and back again. - changed the oil, set the timing, and all the other stuff that can make a 5 degree difference. - Although a new rad cap should eliminate the problem I still checked the hoses and none of them are collapsing under revs. Am I avoiding the obvious... that I just need a new rad, or is there something I am missing? Thanks all.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
