06-14-2018, 06:24 PM | #1 |
How to remove steel bed floor?
68 fleetside bed. What is the procedure for removing steel from bed floor? Tried to search but no luck. Converting from steel to wood. Already have new supports, front strip and wood bed rear tailpan. Thank you for suggestions.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
06-14-2018, 10:24 PM | #2 |
Re: How to remove steel bed floor?
Unbolt it?
06-15-2018, 12:28 AM | #3 |
The bedsides?
06-15-2018, 09:53 AM | #4 |
If you are talking about removing a spot welded in piece, this "Basics of Basics" should give you everything you need.
http://www.hotrodders.com/forum/basi...ls-222549.html Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
06-15-2018, 05:24 PM | #5 | |
06-17-2018, 02:47 PM | #6 | |
Brian
06-17-2018, 10:31 PM | #7 |
the entire floor unbolts, there are two welds at the rear (two on each side). Slice through them with a die grinder. The bed sides sits on top of & bolts to the edge of the floor as does the front panel. The cross sills under the bed floor are spot welded to the floor.
The pen points to the top weld, the lower weld is to the left of the pen. |
06-17-2018, 11:22 PM | #8 |
I had to remove some weld near the tail gate like in the pic that will let you separate the sides form the floor at the rear.
06-18-2018, 07:34 AM | #9 |
Ok tks. So the sides do have to come off. That info will definitely get me going for awhile. I ll just leave cross sills attached to nasty steel floor and remove as a unit if possible. Tks again everyone.
