Old 06-16-2018, 03:58 PM   #1
ScottH
ScottH's Avatar
Exclamation Gauge cluster light issues
So I finally got my 67 running. A few small gremlins to fix, some of them r driving me nuts. Biggest issue is with the cluster lights.
First the generator light stays on all the time when the key is on. Changed the voltage regular & battery is getting 14.7 volts when running. Any ideas why the light is staying on?
Secondly the oil pressure light doesn't work at all. Changed the bulb, pulled the connection from the sender & grounded it, still no light.
Third, blinker indicator lights don't work, either one. Blinkers all work fine, four way flashers as well, changed the bulbs.
Any ideas or suggestions would be appreciated.
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 06-16-2018, 04:54 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Gauge cluster light issues
Check the printed circuit board on the back of the cluster and make sure none of the traces are damaged. Also check the copper traces where the connector plugs in and make sure none of the copper foil tabs have come loose and are shorting across to another tab.
Here is a picture of the cluster ground. The wire goes into the under dash loom and comes back out and connects to the cluster connector where the arrow is pointing. Make sure the connections are clean and making good contact..... Also clean the contacts on the plug. I have found that a fine scotch brite or pencil eraser works good for that.
LockDoc
Leon
Old 06-16-2018, 08:53 PM   #3
ScottH
ScottH's Avatar
thanks very much, I will check it out
