![]() Join Date: Sep 2016
Temp sending unit
Call me crazy but I’ve owned my truck for over a year and the temp gauge has barely moved off cold. After reading on this forum how to troubleshoot to see if it was the gauge or sending unit. I found the the sending unit was indeed bad. So I just replaced it with a new one that I ordered online from Lectric Limited and am happy to say my gauge is working properly and want to say how thankful I am that everyone shares this information for everyone to use.
#2 | |
The Older Generation
Re: Temp sending unit
Good deal. There is certainly a lot of useful information on here. Thanks for posting up the success story on your troubleshooting.... LockDoc
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Times 2 for me. This is a very common problem and your advice will help many.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Scrapper 1
if that did not fix your problem i be looking at a fuse block an having to replace it.the old wires are just that old how many have had a wire fire under the dash 2X here one in my 1965 3/4 ton and a truck i was driving fror a roofing company 1966 3 ton bob tail
Scrapper 1
by chance are you using the 1967-68 UPPER radiator hose that goes straight out here is the hose number #3598556TH GM/AU plus they make the upper thermostat housing here are the pics of the unit and the hose and the housing this only works if you have a Edelbrock ALUM INTAKE MANIFOLD
