07-21-2018, 04:04 PM | #1 |
67 Ignition Switch and Ash Tray oon 68 - newer dash
I understand the bezel is bigger on the newer dashes, but what piece goes on the switch to hold it on the backside of the dash? Anyone have any pictures? I see I can buy a new bezel but I cannot find anything for the backside :/
Also, what about the ash tray? My 67 dash I am removing does not look the same as the new dash I have now. Do I need to get a complete new setup? -Paul |
07-21-2018, 04:24 PM | #2 |
Re: 67 Ignition Switch and Ash Tray oon 68 - newer dash
the 67 parts are 1 year only if your using a 68 dash you need 68 parts .
07-22-2018, 08:28 AM | #3 | |
-Paul |
07-22-2018, 10:31 AM | #4 |
Here you go , The lighter is different also
http://www.manestruckparts.com/store...&Category_ID=8 http://www.manestruckparts.com/store...&Category_ID=8 |
07-22-2018, 07:41 PM | #5 |
The Older Generation
That is called an ignition switch spacer. If you have a '67 with the small screw on bezel here is the spacer you need. http://67-72chevytrucks.com/vboard/s...d.php?t=747570 If you have a '68-'72 with the large screw on bezel any parts vendor will have that spacer. LockDoc
