Old 08-18-2018, 03:01 AM   #1
gseuser
LS gas tank for 65?
Hey everyone, my dad and I are doing a father/son project by LS converting my 1965 C10. We were wondering where can we find a gas tank that will work with the LS conversion? Musclerods doesnt have any and I cant find any info. Any help would be appreciated!
gseuser is offline   Reply With Quote
Old 08-18-2018, 09:10 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: LS gas tank for 65?
You can buy one made for your truck and made for EFI in tank pumps:
http://nolimit.net/products#!/Fuel-T...tegory=6157547
If you can weld you can make a new stock tank work:
https://www.summitracing.com/parts/clp-ufpk-fi (although you can get it cheaper at Tanks I think).
One of the favorites here is Boyds Tanks:
https://www.fueltankparts.com/67-72-...-bed-fill.html
Old 08-18-2018, 10:46 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Boyd welding!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-18-2018, 11:01 AM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
X3---Boyds
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-18-2018, 11:20 AM   #5
Macdaddy1
I went with Tanks Inc. for my 65 tank conversion
Macdaddy1 is offline   Reply With Quote
Old 08-18-2018, 12:16 PM   #6
SkinnyG
SkinnyG's Avatar
On a recent EFI conversion, I ran a low pressure pump out of the tank to a surge tank, which fed an external high pressure pump. Return goes back into the surge tank, and overflow goes back into the fuel tank.
Advantage #1: You're not cutting up an original gas tank, or compromising the internal coatings.
Advantage #2: You can run on almost fumes, and never starve the high pressure pump of fuel.
Disadvantage: Complexity.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-18-2018, 12:33 PM   #7
DLW
I too run a boyds tank with my LS3 conversion. Sweet tank, and it is baffled.
http://www.boydwelding.com/
DLW is offline   Reply With Quote
Old 08-19-2018, 10:28 AM   #8
Hack_Attack
Hack_Attack's Avatar
That sounds interesting.....do you happen to have a thread about how you went about doing this?
Hack_Attack is offline   Reply With Quote
Old 08-19-2018, 11:08 AM   #9
SkinnyG
SkinnyG's Avatar
No, but this is the plan:
Old 08-20-2018, 10:57 AM   #10
Hack_Attack
So, the surge/reservoir tank......what is the capacity of that tank and where did you locate it?
Old 08-20-2018, 11:27 AM   #11
SkinnyG
SkinnyG's Avatar
One car was my Lotus Super 7 replica, and it was at the back of the frame near the tank. I autocrossed this car on slicks, and I wanted to run as light on fuel as I could without starving the pump.
One was my '77 Silverado, and I tucked it inside the frame rail just ahead of the dual tank switch, with an AC Delco electric pump feeding it, and a Ford F150 pump drawing from it. This setup was cheaper than buy two EFI tanks and two EFI pickups and two EFI pumps.
On my V8 Pontiac Firefly I built the fuel tank with a sump inside that WAS the method for fuel to get from the left to the right side of the tank, in the hopes of limiting starvation without running a second pump.
I usually make them about a liter in volume, I'm not sure there is science behind it. The best is tall and narrow, so the outlet is always covered with fuel.
There are a number of aftermarket manufacturers that have a "Fuel Center" which your low pressure pump fills, and a high pressure pump inside does the rest. I have not used one, so I cannot speak to how awesome or wretched they are.
example: https://www.summitracing.com/int/par...0003/overview/
My plan on my '61 is get an EFI Suburban tank and run it at the back.
Old 08-20-2018, 02:57 PM   #12
Hack_Attack
Thanks so much for the reply.....you have the gears turning in my head now.
Old 08-22-2018, 07:47 AM   #13
Bret B
Make it easy on yourself and go with Boyds, with the pump and get the filter/regulator kit at the same time. I bought my Boyds through AZPerformance, good people.
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 08-22-2018, 08:34 AM   #14
zach_carver
zach_carver's Avatar
Another vote for boyds tank, I love mine
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 08-22-2018, 12:58 PM   #15
raic65
raic65's Avatar
I use a stainless Vaporworx tank from Rick's Tank. It uses a Gen V Camaro fuel pump module. Easier to plumb because there is no return line. Tank can run down to near empty without fuel starvation issues. Have about 50k miles on it.
https://rickstanks.com/product/vapor-series/
raic65 is offline   Reply With Quote
Old 09-17-2018, 03:26 PM   #16
Warship2k15
What model one??
I see them but it doesn’t have c10 listed so which one did you use?
How’s the filler neck?And where is it located?What controller are you using??
Warship2k15 is offline   Reply With Quote
Old 09-17-2018, 03:50 PM   #17
raic65
raic65's Avatar
Originally Posted by Warship2k15 View Post
What model one??
I purchased the tank through Matt's Classic Bowties. I use the bed fill version PN 055003. You need to scroll down to the very bottom on the GM tab on the Rick's Tank site. I am not using a controller. I'm using the 5th gen SS pump with a retro-fitted fuel pressure regulator.
Old 09-17-2018, 03:56 PM   #18
Warship2k15
Just found it.
Old 09-17-2018, 06:40 PM   #19
Cris
raic65:
How far below the frame rails does the tank sit? Can it get installed/removed without removing the bed? Sounds like a great tank.
Thanks, Cris
Cris is offline   Reply With Quote
Old 09-18-2018, 10:22 AM   #20
raic65
raic65's Avatar
Originally Posted by Cris View Post
raic65:
Thanks, Cris
Cris,
I'd have to go and measure. The tank is installed/removed from the bottom. Does not require removing the bed.
Robert
Old 09-18-2018, 04:22 PM   #21
Cris
Thanks Robert, I'd like a tank that can't be seen. Thinking of doing a FI conversion on my I-6 (Holley Sniper Two Barrell) and need a tank. I like the no return line approach.
Cris
Old 09-19-2018, 09:36 AM   #22
raic65
raic65's Avatar
Cris
If you're looking to install a sniper and using a different tank than the Rick's Tank, look at Holley's Retrofit Returnless Fuel Module. I used it in my brother-in-law's 66 mustang. He is running the sniper on a warmed-up 302. I didn't want to deal with a return line on it either and used the retro-fit module. All you do is plug the return port on the sniper unit.
https://www.holley.com/products/fuel...e/parts/12-131
Old 09-19-2018, 09:51 PM   #23
Cris
Robert:
Thanks, that’s a good find. I may go with a custom tank to keep it tucked up on the truck. I don’t need more than 14 gallons and many aftermarket tanks seem to focus on capacity not size (height hanging down).
Cris
Old 09-19-2018, 11:57 PM   #24
Captainfab
60-66 Nut
Here's one of a few options from Tanks Inc.
http://www.tanksinc.com/index.cfm/pa...rod/prd279.htm
Old 09-20-2018, 11:34 AM   #25
Cris
Captain, thanks:
I talked to these guys at a Good Guys show. That tank hangs a little low for my taste and requires a little hacking of the frame to fit. They know it’s not perfect for our trucks and are at least thinking of a dedicated tank. The more people that ask about it the faster they’ll move!
Cris
