Old 09-12-2018, 10:22 PM   #1
Houston Ben
Houston Ben's Avatar
How to lower rear after 4” shackle/hangar drop
Hi all,
Had a 2/4 drop, now have a 4.5/4 drop. Would like to lower rear 1”-2” more, any ideas how?
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 09-13-2018, 07:54 AM   #2
Re: How to lower rear after 4” shackle/hangar drop
Easiest way would be to go back to factory hangers and shackles, then do an axle flip.
Old 09-13-2018, 09:08 AM   #3
cochino12
It followed me home?
cochino12's Avatar
^^^ what he said
or you could remove a leaf or two
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-13-2018, 11:24 PM   #4
Houston Ben
That’s what I thought. I read mixed reports on if I need a C notch or not, is it necessary?
Old 09-14-2018, 03:38 PM   #5
Tom
driving is in my blood
Tom's Avatar
You can also de-arch the leafs, or buy lowered leafs.
Old 09-14-2018, 03:45 PM   #6
PunishedC10
You will want to C notch if the rear end is slamming up against the frame.
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 09-17-2018, 12:31 PM   #7
Houston Ben
Thanks all!
Old 09-25-2018, 02:14 AM   #8
bbbc10
Diggin The SquareLife
I had 6" drop an didn't need a notch but if you plan to tow or haul stuff you will need one
bbbc10 is offline   Reply With Quote
Old 09-25-2018, 12:24 PM   #9
bigblock73
yeller
bigblock73's Avatar
After doing a shackle/hanger drop years ago...then wanting to go lower, I took it all back out and did a flip. I would never recommend a shackle/hanger drop to anyone...just because it locks you in to that drop for the most part. With a flip, its easier to install and gives you more options to go lower in the future if you decide to.
bigblock73 is offline   Reply With Quote
Old 09-30-2018, 05:26 PM   #10
Houston Ben
Thanks bigblock, I think I may take the overload spring out and put bags in later. IDK, we will see what I do.
