Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-31-2018, 09:17 PM   #1
Project86
aftermarket yokes/ujoints
so i had a series of unfortunate events happen the other day.
took the c10 out for a little fun drive.
pedaled the truck a couple of times, then my driveshaft decided it didnt want to stay along for the ride and completely fell out.
transmission yoke has a broken ear, the pinion yoke has a rounded out bolt hole and the ujoint saddles are trash.
so now i need a new slip yoke for the th400 as well as a new pinion yoke.
are there any better than stock yokes that dont break the bank, that will hold up to a full built 383 stroker and built th400
Project86 is offline   Reply With Quote
Old 10-31-2018, 10:03 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: aftermarket yokes/ujoints
If you want top shelf stuff go Mark Williams, if you want good stuff but less money try Moser or Strange, there are others out there, but those are my usual brands I run that are available and easy to get.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-02-2018, 03:57 AM   #3
Project86
would the Strange nodular iron trans yoke part number U1650 work fine?
if need be i can just wait and order the CM yoke which is $180.
so in my head what i am thinking is i could save up for the chromoly trans and pinion yoke. and use their heavy duty spicer 1350 u joints. as well as their HD cap kit.
Old 11-02-2018, 07:00 AM   #4
71Dragtruck
Wait and get the CM.
Sponsored by:
Hard Candy Customs
Old 11-02-2018, 07:45 AM   #5
regan wilson
regan wilson's Avatar
I was going to chime in on this yesterday. I have been using a Mark Williams front yoke with 1350 u joints for nearly 20 years.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 11-04-2018, 03:57 AM   #6
Project86
now i will say that i love his yoke setups and the ujoint straps.i just cant fathom dropping over $300 for a yoke. granted its very well worth it.
Old 11-04-2018, 09:29 AM   #7
71Dragtruck
I've exploded a Spicer trans yoke before, it took out my trans tail shaft housing and had to repair the driveshaft (hairline crack I didn't notice until it split next trip to the track), in the long run cost me 2 breakdowns out of town at the track, plus ended up buying that $300 yoke eventually anyway.
So it would have been the better deal to upgrade mine long before it broke and caused other damage, pay once cry once.
Sponsored by:
Hard Candy Customs
Old 11-06-2018, 12:23 AM   #8
Project86
what engine/trans setup are you running?
Old 11-06-2018, 01:17 PM   #9
71Dragtruck
Right now a 489 BBC on nitrous and a built turbo 350, this setup is coming out in the spring and a new combo is going in of a all aluminum 615 BBC with 20* heads and a turbo 400.
Sponsored by:
Hard Candy Customs
Old 11-06-2018, 09:53 PM   #10
Project86
nice!! yeah youre putting out probably double what my built 383 is making
Old 11-07-2018, 10:12 PM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
If the tail is roller bearing CM is your only choice.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-10-2018, 01:17 AM   #12
Project86
its just a virtually stock th400 so i have no idea..
Old 11-10-2018, 02:25 AM   #13
71Dragtruck
Won’t be a roller tail housing if stock, will be bushing.
Sponsored by:
Hard Candy Customs
Old 11-10-2018, 03:34 AM   #14
Project86
ah ok. makes sense then. so a regular slip yoke will suffice, or better yet an aftermarket one
