12-20-2018, 10:51 PM | #1 |
What mufflers Are you using?
I have long tube headers and chambered mufflers on my sbc 69 c10.
Thinking about going to glass packs right off the headers. What are all of you using? Last edited by LockDoc; 12-20-2018 at 11:13 PM. |
12-20-2018, 11:19 PM | #2 | |
The Older Generation
Re: What mufflers Are you using?
I am using Hooker cast iron headers and Flowmaster Series 40 knockoffs with pipes all the way back on the Panel Truck. They had a bad drone at about 60 mph so I added "J" pipes behind the mufflers and it sounds great now. LockDoc
12-20-2018, 11:26 PM | #3 |
Excuse my ignorance......what is a J pipe?
12-20-2018, 11:44 PM | #4 |
Short pipes that are shaped like a "J". They weld into the exhaust pipes behind the muffler. They have to be a certain length depending on what RPM the drone occurs. If you type J pipe exhaust into Google it will explain them.
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-24-2020 at 10:51 AM. |
12-21-2018, 01:52 AM | #5 |
Wow, I had no idea.....I'm 56 years old and have never heard of that!
I didn't google it but does the tone change much? Thanks Locdoc! Blake |
12-21-2018, 09:36 AM | #6 | |
Personally, I want to make good power and be more quiet these days. I’m running Dynomax Hemi Turbo mufflers on my Jimmy and have a second set for my short step when the big block goes in. I have a set of Jones Turbo Tubes attached to the end of the headers on my AMC 360 in my CJ-5 and that’s always enough to remind me what I don’t want in my truck!
12-21-2018, 01:31 PM | #7 | |
Here is a chart to calculate the length you need. You can't just make them any length and expect them to work. That's why I recommend doing some reading on them. I think mine are 23.5 inches long. LockDoc
12-21-2018, 01:36 PM | #8 |
I think you can count on a pretty annoying drone with that combination. If you like noise it should work well.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-21-2018, 01:42 PM | #9 |
I'm running 3" spintech mufflers, x pipe, hooker headers. It's little loud for me from the inside, but I like the sound from the outside.
https://www.youtube.com/watch?v=J5CxfMAJR5U For a more mellow tone, I've heard great things about Magnaflow mufflers. |
12-21-2018, 03:03 PM | #10 | |
12-21-2018, 03:28 PM | #11 |
I wonder how J pipes compare to a resonator?
I'm running some kind of Turbo mufflers. Think they are Hookers. I've run turbo mufflers in just about everything I put performance exhaust on. I really like them. Much better sounding than stock, but still quiet enough for a daily driver.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
12-21-2018, 04:23 PM | #12 | |
Right in that area, yes. @65mph LockDoc
12-21-2018, 10:03 PM | #13 |
Old member
I'm running Chip Foose Magnaflows on my 71 with dual exhaust all the way to the rear corners. I'm running Stainless Works full Length headers from
https://stainlessworks.net/ Aluminum 2.5" tubes. They are nice for normal driving but when you get on it they will talk to you!
12-24-2018, 11:16 AM | #14 |
Are you trying to make everyone hate you and give yourself a migraine every time you drive it?
Anyway, what's your end goal for sound? Aggressive? Tough, but subtle? Vintage 60s-70s sound? Smooth idle and cruise, but really talks at hard throttle? Piss off your neighbors at 6:00 AM?
12-24-2018, 11:43 AM | #15 |
I really like my big DynoMax. Quiet and low-toned at idle, NO drone at cruise, but loud and angry when under load. Seems like the best of all worlds.
12-25-2018, 09:17 AM | #16 |
Ive got headers and had a set of turbo mufflers, sounded pretty good but a little on the quiet side. When I did my engine swap, i swapped out for a aet of hooker max flows. The performance is there, but still rather quiet and wimpy sounding?
Posted via Mobile Device |
12-25-2018, 11:20 AM | #17 |
1970 c10
350cu TH350 auto Mostly stock engine with a few upgrades Summit ceramic long tube headers Custom 2 1/2" exhaust Flowmaster 40 series delta flow H pipe Pipes come out under bumper No drone at all. Not too loud. Rumples nice at idle Barks when you step on it. Normal driving you can hear radio etc. not obnoxious. A couple videos of the sound. Quiets down after engine warmed up too https://m.youtube.com/watch?v=Q4hRlBLtOng https://m.youtube.com/watch?v=s4iNCxKl8RA
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
12-25-2018, 12:04 PM | #18 |
My challenger has flowmasters and is screams a lot (loud) and my c10 402 has magnaflow and they are perfect
12-25-2018, 06:31 PM | #19 |
on my 509 merlin3 I'm using Dynomax ultra flo round.I shake my neighbors coffee cup when i drive by his house.
12-25-2018, 08:49 PM | #20 |
I was hoping the dynomax ultra flows would be a little quieter. Maby the oval ones are.
12-26-2018, 01:14 PM | #21 |
I am running a set of spintechs. Long tube headers with an H pipe and the pipes run all the way to the rear. So loud you cannot hear the stereo or talk to the passenger at idle or cruising. I'm going to swap out to some magnaflows in the spring.
Spintechs were cool for a bit, but not any more. |
12-26-2018, 02:22 PM | #22 |
Keep in mind most manufacturers offer several models and types of mufflers. So to say flowmaster is too loud or maganflow more quiet really isn't accurate.
Need to specify which muffler you are referring to Good idea to go on youtube and see vids on various brands and models. Hope that helps. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 12-27-2018 at 10:57 PM. |
12-26-2018, 05:12 PM | #23 | |
I spent weeks researching and am still dying to know a great sounding muffler with little to no drone, can carry on a conversation with your significant other in the cab, but still has some bark when you mash the pedal. The other thing I can testify to is hp changes the sound as well as camshaft. A lopey cam makes any exhaust sound awesome! Posted via Mobile Device |
12-26-2018, 06:04 PM | #24 | |
12-27-2018, 02:34 PM | #25 | |
