01-02-2019, 08:23 PM | #1 |
Heater controls ?
My heater controls ( no ac ) righting is need of replacement. ( the clear thing with righting saying what each lever does.) not shure what to call it.
Any way the qustion i have is how do you remove it? And can you get a new one?
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
01-02-2019, 08:59 PM | #2 |
Re: Heater controls ?
Ok i just did a quick Google search and found whare i can get it and levers to. I need one anyway. Still need to know how to disaemble it. Maby ill take it out tomarrow and fidle with it.
01-02-2019, 10:03 PM | #3 | |
The Older Generation
There are two phillips head screws under the edge of the dash that hold the unit in place. The light bulb holder plugs into the left side in the back, and the wiring for the heater switch plugs into the switch on the right side. Here is a thread I posted about removing the small round keepers from the control cables: http://67-72chevytrucks.com/vboard/s...d.php?t=211815 and a thread where I posted which cables go where on the heater boxes (Post #4): http://67-72chevytrucks.com/vboard/s...d.php?t=241369 LockDoc
01-02-2019, 10:08 PM | #4 |
Thanks but my fan swich is whare the cigarette lighter was. The keepers are the same as the other end of the cable for the heater box. I did not
have a problem removing them. Are the arms really that fragal
01-02-2019, 10:13 PM | #5 |
Do you only have one fan speed then? This would be a good time to put it back to original as long as you have to take it out anyway..... LockDoc
01-02-2019, 10:29 PM | #6 |
It two postion swich. High and low. And I do plan on redoing it how it's sappose to be. I need to get a new fan swich and a blower motor. It works but makes some nasty soundes
01-03-2019, 01:32 AM | #7 | |
The best thing to do would be to get the whole setup out of a junk yard truck, that way you would know you have everything you need..... LockDoc
01-03-2019, 02:26 AM | #8 |
I was under the dash today and it looks like every think is there. Gess ill find out tomarrow when i take it out
01-03-2019, 12:53 PM | #9 |
Got the controls out today. Now I need to get the rivit's out of the part that lights up. Any one know a good why to reattach that peace? Jb weld?
01-03-2019, 02:16 PM | #10 |
Got it all polished up
01-03-2019, 02:25 PM | #11 |
Drilled out the rivits now I just need a new clear plastic thing
01-03-2019, 02:27 PM | #12 |
Here the picturer
01-03-2019, 07:30 PM | #13 |
I'm not going to order on of those kits. They don't have the clear plastic part. Instead the give you a skicker to put over it. I don't like that and it doesn't come wit a new fan swich. $ 40 for the kit +$20 for the swich. $60 total. I don't have the funds for that right now so instead I'm going get another asembly form another pickup. Well a c50. Thare the same right? As for the swich I'll get a new one but not right now looks easy to replace under the dash
01-03-2019, 09:13 PM | #14 |
Good luck man. One of my arms are broke, I'll be buying one of those arm kits and trying to fix it soon.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
01-03-2019, 09:26 PM | #15 | |
Not sure on the C50, it's been a long time since I looked at one. If the C50 unit will work it should have the switch on it. Don't forget to get the resistor. It will be in the top of the interior heater box. The wires from the switch run to it and it takes a 5/16 wrench to remove it. Be careful with it, it can be kind of fragile.... LockDoc
01-03-2019, 09:57 PM | #16 |
That's the great thing when they redid the swich they left every thing thare all I have to do is reconnect one wire and it's back to stock.
01-03-2019, 10:58 PM | #17 | |
LockDoc
01-04-2019, 12:41 PM | #18 |
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
01-06-2019, 03:24 AM | #19 |
I got a new header control today one from a 67 c20.
It had a better display and the lever i needed. The back of the top lever whare the cable attached to was broken on the new one so I tryed to remove the knob on it so if I broke it it did not matter. Well let me tell you those knobs don't whant to come off. I ended up brakeing it. So I will not try it with the lever I need. Ether way I still came out on top. The heater controls where not the only thing I grabed I allso got a taillight and a horn button. I gusess I will buy one of those rebuild kits avenchaly Picher 1st one on the right is the new one one on left is old 2nd old controls with new display 3rd new conto with old display
01-06-2019, 11:35 AM | #20 | |
Looks good! The knobs will come off but they can be pretty tough sometimes. Good score on the extra parts LockDoc
01-06-2019, 12:17 PM | #21 |
Thanks now to put it back in till I can get the rebuild kit
01-06-2019, 12:50 PM | #22 |
GREAT NEWS I got the knob of the fan speed lever with out braking it. Took me a wile. But I got it
01-06-2019, 01:02 PM | #23 |
Here's my lever
01-06-2019, 01:11 PM | #24 |
All put back together.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) Last edited by 71gmcC15; 01-06-2019 at 03:04 PM. |
01-06-2019, 10:51 PM | #25 |
I knew you would get it.
Lookin' good! LockDoc
