01-30-2019, 08:27 AM | #1 |
Rear axle locator
Has anyone used a wishbone style rear end locator with stock style trailing arms?
01-31-2019, 12:38 PM | #2 |
Post Whore
Re: Rear axle locator
Could you be more specific on wishbone?..pics are nice....
if it's what I think your asking about it probably won't work
02-18-2019, 02:52 PM | #3 |
02-18-2019, 03:46 PM | #4 |
Moderator
02-18-2019, 03:52 PM | #5 |
You can't use a wishbone if you keep the axle solid mounted to the trailing arms like factory... unless you figure out the instant center of rotation and build the wishbone and mounts to share the same instant center.
You can, however, add a pivot to the axle mounts via some bushings or rod ends and use a wishbone, but at that point you'd be better off just replacing the factory trailing arms with some custom links. Either way, you'd effectively have a wishbone 3 link. The key is adding a pivot point to the lower arms so they don't bind. |
02-22-2019, 08:07 AM | #6 |
A wishbone works good in a drag car but they are not designed to take the cornering loads that we see in street driving.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-22-2019, 11:40 AM | #7 |
